Cubuss
[How can i run a bash script on boot with Pi 4B /4GB]
Sun Sep 15, 2019 2:46 am
i need to run a simple .sh script on boot that requires internet,
But it doesnt start when i reboot or boot the pi, i already tried using crontab
@reboot script.sh
also tried messing around with rc.local with no luck,
Any suggestion or help is appriciated
Gavinmc42
Re: [How can i run a bash script on boot with Pi 4B /4GB]
Sun Sep 15, 2019 4:49 am
My scripts wait until there is a valid IP address.
Then they send me an email so I know what it is.
It can take some time before the server on a network assigns it.
30 secs after booting is not unusual.
I'm dancing on Rainbows.
jbudd
Sun Sep 15, 2019 7:23 am
You shouldn't assume that cron knows where to find your script. It's best to use the full pathname.
If you redirect the script output to a logfile you may get a clue to what went wrong.
Try @reboot /home/pi/script.sh >/home/pi/script.log 2>&1 (or wherever script.sh is).
You could put sleep 10 in the script to see if that gives time for a connection
graysky
Sun Sep 15, 2019 8:12 am
You could write systemd service to execute it for you once the network is up rather than a sleep line... I assume your distro is using systemd.
For an example, see: https://github.com/graysky2/odroid-auto ... ge.service
