alanchee
Bluetooth Data Logging Project
Mon Sep 09, 2019 3:27 am
Hello everyone, I am interested in conducting a data logging system via Bluetooth. The basic premise of the project consists of a Raspberry Pi Zero W receiving data from accelerometers (ADXL345) via Bluetooth (HC - 05 Bluetooth Module).
As my knowledge with this is fairly new, I would like to know if these components be compatible with one another? If it isn't, can anybody point me in the right direction?
Your help is greatly appreciated.
deepo
Re: Bluetooth Data Logging Project
Mon Sep 09, 2019 11:37 am
The Bluetooth components of both the RPi Zero W and the HC - 05 module should have no problems talking with each other.
If you aim for Bluetooth Low Energy advertisement telegrams, then bluepy for Python could be of use to you.
https://github.com/IanHarvey/bluepy
If you aim for paired Bluetooth connections, then of course Python can do that too.
/Mogens
Douglas6
Mon Sep 09, 2019 1:38 pm
No problem communicating between a Pi and an HC-05, although BLE is not an option.
However, from what I can see, communications between an ADXL345 and an HC-05 may be a problem. I notice Adafruit has an ADXL345 breakout board, but only with I2C / SPI interfaces. The HC-05 requires a serial interface.
deepo
Mon Sep 09, 2019 5:09 pm
What about the Adafruit Bluefruit LE SPI Friend
https://www.adafruit.com/product/2633
It has SPI interface, but maybe only for accessing the Bluetooth chip, and not for collecting data as OP wants?
/Mogens
