Kzitold
What's the best way to track uptime until unexpected shutdown?
Thu Aug 29, 2019 7:15 pm
Need to figure out how long my biggest battery would power my Pi for... travel reasons. Would be using it over VNC on my phone/tablet, probably using RaspAP to do so (assuming that makes VNC any easier.)
If I were to attempt figuring out how to time it myself, I would try an automated script that occasionally notes the time in a file, and that seems kinda inefficient.
By the way, I know practically nothing about Raspbian scripting/automation, so I could use some help with that if needed. My only experience with something similar is Powershell scripting.
neilgl
Re: What's the best way to track uptime until unexpected shutdown?
Fri Aug 30, 2019 12:11 am
What pi is it ? Pi zero or pi4 etc..?
jbudd
Fri Aug 30, 2019 1:19 am
There is a Linux command to tell you how long the system has been up - uptime, probably best used with the "pretty output" option uptime -p
So to record uptime in a file uptime.log every minute you could type this at the command line. The & makes it run in the background without tying up the command line. It will run as long as the power supply lasts, as long as you don't log out.
while true
do
uptime -p > /home/pi/uptime.log
sleep 60
done &
Fri Aug 30, 2019 4:18 am
One issue with this is that if the Pi dies due to the battery running low while it is writing to the file you may end up with a corrupted file.
If connecting via a remote terminal you could run something simple that displays uptime every minute or less, so you will see the last uptime value when the Pi dies. That is good as long as the remote doesn't close its window when it loses connection.
If I were doing this at home, I would write to a file on my NFS share server. It is unlikely the file would get corrupted by a sudden loss of power, as the data would either reach the server or not.
Gavinmc42
Fri Aug 30, 2019 5:40 am
cron or watch can write the uptime to a file every minute or so.
No need to put a software sleep in that, just chews more cpu cycles.
I'm dancing on Rainbows.
epoch1970
Fri Aug 30, 2019 7:42 am
“sleep 60” does not cause any extra load.
To avoid the issue of file corruption in case of sudden power off you can flip-flop between two files. At least one will stay good.
I think I would “ping -c 1” the machine from the network instead.
RaTTuS
Fri Aug 30, 2019 7:44 am
sudo apt install uptimed
uprecords
Covfefe
Fri Aug 30, 2019 8:12 am
uprecords
Last time I looked that hadn't made it into Buster, so I ended up pulling it from the Stretch repo.
This is a doctor free zone.
RaTTuS
Fri Aug 30, 2019 8:21 am
umm it's on my Pi4 buster and I didn't do anything special apart from the install
Covfefe
Fri Aug 30, 2019 8:41 am
I can confirm uptimed is in Buster
rpdom@raspi12:~ $ apt-cache policy uptimed
uptimed:
  Installed: (none)
  Candidate: 1:0.4.1-1
  Version table:
     1:0.4.1-1 500
        500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages
Fri Aug 30, 2019 9:15 am
It may be the uprecords-cgi piece that's missing.
hippy
Fri Aug 30, 2019 1:00 pm
If the battery turns itself off when expired, stops outputting voltage; one simple means of measuring roughly how long it lasted is to power an electro-mechanical clock from it. That will stop turning when the power is removed.
