papallot
Using feh over ssh connection
Sun Jul 14, 2019 12:49 pm
I am trying to open a picture in my raspberry pi 3b+ from my computer (I have linux mint installed).
It is very basic:
-I connect to the raspberry:
ssh pi@192.168.1.61
-I introduce my password
-Once I am in the raspberry, I execute feh:
feh /home/pi/mypicture.jpg
the following error apperars: "feh ERROR: Can't open X display. It *is* running, yeah?"
Doing some readying, I can solve it by typing on the command line
export DISPLAY=:0
After this, it works perfectly.
Is there a possibility to do that automatically? I have tried to put it in the autostart file but it doesn't work
Thanks a lot
scruss
Re: Using feh over ssh connection
Sun Jul 14, 2019 1:40 pm
If you do
ssh -X pi@192.168.1.61
it should set up DISPLAY correctly
papallot
Sun Jul 14, 2019 3:09 pm
Thanks for the answer.
I have tried with that, but it still doesn't work.
After logging in to my raspi as ssh -X 192.168.1.61, if I write "printenv", I see that currently the variable "DISPLAY" is set to "localhost:10"
When I run feh, nothing happens on the screen and the terminal is stuck. I can carry on with ctrl+z.
Thanks!
Sun Jul 14, 2019 3:51 pm
Are you trying to get the image to display on the monitor connected on the Pi, not on the PC you're using for ssh?
ssh -X makes the Local display the one to output to.
To get it to display on the Pi you'll need to set the DISPLAY variable once logged in.
papallot
Sun Jul 14, 2019 4:55 pm
Yes, that is correct. I am displaying the images on a screen connected to the pi with hdmi.
How can I change the variable automatically?
Thanks a lot
scruss
Sun Jul 14, 2019 6:01 pm
Untried - and possibly in the wrong config file - but add the following near the end of your ~/.bashrc file:
if [ -n "$SSH_CLIENT" ] || [ -n "$SSH_TTY" ]; then
	if [ -n "$DISPLAY" ]; then
		export DISPLAY=:0
	fi
fi
This should set the display to use the Raspberry Pi's monitor over ssh, but still respect a remote ssh -X request if you do ever want to display things locally.
papallot
Sun Jul 14, 2019 7:55 pm
Awesome, that kind of worked!!
I had to remove the inner if because, I don't know why, the condition [ -n "$DISPLAY" ]; it goes false.
	export DISPLAY=:0
fi
I tried that and everything works perfectly. Thanks a lot!!
If you don't mind, I would like to ask another related question:
I need to make the call from another raspberry and I am doing it inside another python script:
import sys
import subprocess
subprocess.call("ssh pi@192.168.1.61 feh /home/pi/mypicture.jpg",shell=True)
Apparently it doesn't work, the same error appears. I have done some debugging and the file ~/.bashrc is not being run.
thanks again
klricks
Mon Jul 15, 2019 12:58 pm
Have you tried using the DISPLAY=:0 directly from ssh prompt?
DISPLAY=:0 feh /home/pi/mypicture.jpg
