5t4n5
Moving an image file...
Sun Jul 14, 2019 4:57 am
I right click on an image file, copy it, then go to other folder and right click, paste it, and i get 'Permission denied'.
I keep getting permission denieds on lots of files that i simply want to move from one folder to another.
How do i fix this? What's wrong? Help please.
Honestly, i've no idea what i'm doing. :oops:
rpiMike
Re: Moving an image file...
Sun Jul 14, 2019 5:25 am
What is the full path of the folder that you want to move from and to?
5t4n5
Sun Jul 14, 2019 6:02 am
/home/pi/Desktop moving to /usr/share/rpd-wallpaper
HawaiianPi
Sun Jul 14, 2019 7:22 am
Anything outside of your home directory needs elevated permissions. Just keep your pictures in the /home/pi/pictures folder (or learn how to copy things from the CLI with sudo).
B.Goode
Sun Jul 14, 2019 7:24 am
If you are running a standard version of the Raspbian Operating System, the default pi user does not have write permission for that target.
pi@RPi3BplusOffice:~ $ ls -ald /usr/share/rpd-wallpaper/
drwxr-xr-x 2 root root 4096 Apr 18  2018 /usr/share/rpd-wallpaper/
pi@RPi3BplusOffice:~ $ touch /usr/share/rpd-wallpaper/some_image
touch: cannot touch '/usr/share/rpd-wallpaper/some_image': Permission denied
pi@RPi3BplusOffice:~ $ sudo touch /usr/share/rpd-wallpaper/some_image
pi@RPi3BplusOffice:~ $ ls -al  /usr/share/rpd-wallpaper/some*
-rw-r--r-- 1 root root 0 Jul 14 08:21 /usr/share/rpd-wallpaper/some_image
gkaiseril
Sun Jul 14, 2019 4:57 pm
Use the following command to see the permissions, link count, owner name, size, modified date, file/directory name:
ls -acgh /usr/share/rpd-wallpaper
You should see that all the files are owned by "root" and non-root users only have "read" permission. You might want to study how linux uses users, groups, and sets permissions. You should also review the "sudo" command and be aware this command should be carefully used or one can make there system very difficult to use by non-root users.
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
5t4n5
Mon Jul 15, 2019 1:56 am
Thank you. I see i have some reading to do. :D
