AZAZAZ
SLURM enabled but not starting
Thu Jul 11, 2019 6:08 pm
Hi guys,
Im building a raspberry pi cluster for a project, and I am currently trying to get slurm working. I can enable it, but when i run "sudo systemctl start slurmd", i get the error message shown in the screen shot. COuld this be something to do with the slurm.conf file not being edited correctly by me?
Screen Shot 2019-07-11 at 10.43.28 AM.png (84.64 KiB) Viewed 877 times
DirkS
Re: SLURM enabled but not starting
Thu Jul 11, 2019 6:10 pm
So did you follow the advice in the messages (i.e. check the status to get more details)?
And please post text instead of screenshots.
AZAZAZ
Thu Jul 11, 2019 6:23 pm
Here is what the error code said
 slurmd.service - Slurm node daemon
   Loaded: loaded (/lib/systemd/system/slurmd.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Thu 2019-07-11 11:17:53 MST; 3min 59s ago
     Docs: man:slurmd(8)
  Process: 2097 ExecStart=/usr/sbin/slurmd $SLURMD_OPTIONS (code=exited, status=1/FAILURE)
Jul 11 11:17:53 Masternode systemd[1]: Starting Slurm node daemon...
Jul 11 11:17:53 Masternode systemd[1]: slurmd.service: Control process exited, code=exited, status=1/FAILURE
Jul 11 11:17:53 Masternode systemd[1]: slurmd.service: Failed with result 'exit-code'.
Jul 11 11:17:53 Masternode systemd[1]: Failed to start Slurm node daemon.
DirkS
Thu Jul 11, 2019 6:58 pm
Well, that's not very informative...
You could try to start the program manually (on the command line) and see what the output is.
Or maybe it creates a log file?
AZAZAZ
Mon Jul 15, 2019 8:22 pm
Here is what it reads when i run "journalctl -xe." Do you see anything wrong?
sudo journalctl -xe
-- A start job for unit slurmd.service has begun execution.
-- The job identifier is 1415.
Jul 15 11:16:19 Node02 systemd[1]: slurmd.service: Control process exited, code=exited, status=1/FAILURE
-- Subject: Unit process exited
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- An ExecStart= process belonging to unit slurmd.service has exited.
-- The process' exit code is 'exited' and its exit status is 1.
Jul 15 11:16:19 Node02 systemd[1]: slurmd.service: Failed with result 'exit-code'.
-- Subject: Unit failed
-- The unit slurmd.service has entered the 'failed' state with result 'exit-code'.
Jul 15 11:16:19 Node02 systemd[1]: Failed to start Slurm node daemon.
-- Subject: A start job for unit slurmd.service has failed
-- A start job for unit slurmd.service has finished with a failure.
-- The job identifier is 1415 and the job result is failed.
Jul 15 11:16:19 Node02 sudo[1646]: pam_unix(sudo:session): session closed for user root
Jul 15 11:17:00 Node02 sudo[1658]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/raspi-config
Jul 15 11:17:00 Node02 sudo[1658]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Jul 15 11:17:01 Node02 CRON[1671]: pam_unix(cron:session): session opened for user root by (uid=0)
Jul 15 11:17:01 Node02 CRON[1675]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Jul 15 11:17:01 Node02 CRON[1671]: pam_unix(cron:session): session closed for user root
Jul 15 11:17:30 Node02 sudo[1658]: pam_unix(sudo:session): session closed for user root
Jul 15 11:22:27 Node02 sudo[1720]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/systemctl enable slurmd
Jul 15 11:22:27 Node02 sudo[1720]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Jul 15 11:22:27 Node02 systemd[1]: Reloading.
Jul 15 11:22:28 Node02 systemd[1]: Reloading.
Jul 15 11:22:28 Node02 sudo[1720]: pam_unix(sudo:session): session closed for user root
Jul 15 11:22:30 Node02 sudo[1774]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/systemctl start slurmd
Jul 15 11:22:30 Node02 sudo[1774]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Jul 15 11:22:30 Node02 systemd[1]: Starting Slurm node daemon...
-- Subject: A start job for unit slurmd.service has begun execution
-- The job identifier is 1476.
Jul 15 11:22:30 Node02 systemd[1]: slurmd.service: Control process exited, code=exited, status=1/FAILURE
Jul 15 11:22:30 Node02 systemd[1]: slurmd.service: Failed with result 'exit-code'.
Jul 15 11:22:30 Node02 systemd[1]: Failed to start Slurm node daemon.
-- The job identifier is 1476 and the job result is failed.
Jul 15 11:22:30 Node02 sudo[1774]: pam_unix(sudo:session): session closed for user root
Jul 15 11:22:45 Node02 sudo[1790]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl -xe
Jul 15 11:22:45 Node02 sudo[1790]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
ejolson
Mon Jul 15, 2019 10:34 pm
Hi guys,
Quite likely you have an error in your slurmd.conf file. Exactly where systemd puts the log files, I'm not sure.
Have you checked in /var/log for anything with a slurm in it? Also, have you installed and configured munge already?
drllama
Tue Jul 16, 2019 5:13 pm
The repo version of SLURM stores logs in /var/log/slurm-llnl, have a look there.
I, literally yesterday, put my first RPi4 into my bramble using SLURM. In the end, because I have a mix of RPi3 nodes running Raspian Stretch, and the RPi4 running Raspian Buster, I ended up building latest SLURM from sources.
That said, logs are your friend.
AZAZAZ
Tue Jul 16, 2019 5:34 pm
Attached is the slurm.conf file, could you see if there is anything wrong? Also, I know that munge works on all of the nodes.
#ControlMachine=Masternode
#ControlAddr=ip.ip.ip
SlurmctldHost=ip.ip.ip
AuthType=auth/munge
#CheckpointType=checkpoint/none
CryptoType=crypto/munge
#DisableRootJobs=NO
#EnforcePartLimits=NO
#Epilog=
#EpilogSlurmctld=
#FirstJobId=1
#MaxJobId=999999
#GresTypes=
#GroupUpdateForce=0
#GroupUpdateTime=600
#JobCheckpointDir=/var/lib/slurm-llnl/checkpoint
#JobCredentialPrivateKey=
#JobCredentialPublicCertificate=
#JobFileAppend=0
#JobRequeue=1
#JobSubmitPlugins=1
#KillOnBadExit=0
#LaunchType=launch/slurm
#Licenses=foo*4,bar
#MailProg=/usr/bin/mail
#MaxJobCount=5000
#MaxStepCount=40000
#MaxTasksPerNode=128
MpiDefault=none
#MpiParams=ports=#-#
#PluginDir=
#PlugStackConfig=
#PrivateData=jobs
ProctrackType=proctrack/cgroup
#Prolog=
#PrologFlags=
#PrologSlurmctld=
#PropagatePrioProcess=0
#PropagateResourceLimits=
#PropagateResourceLimitsExcept=
#RebootProgram=
ReturnToService=1
#SallocDefaultCommand=
SlurmctldPidFile=/var/run/slurm-llnl
SlurmctldPort=6817
SlurmdPidFile=/var/run/slurm-llnl
SlurmdPort=6818
SlurmdSpoolDir=/var/lib/slurm-llnl/slurmd
SlurmUser=slurm
#SlurmdUser=root
#SrunEpilog=
#SrunProlog=
StateSaveLocation=/var/lib/slurm-llnl/slurmctld
SwitchType=switch/none
#TaskEpilog=
TaskPlugin=task/affinity
TaskPluginParam=Sched
#TaskProlog=
#TopologyPlugin=topology/tree
#TmpFS=/tmp
#TrackWCKey=no
#TreeWidth=
#UnkillableStepProgram=
#UsePAM=0
# TIMERS
#BatchStartTimeout=10
#CompleteWait=0
#EpilogMsgTime=2000
#GetEnvTimeout=2
#HealthCheckInterval=0
#HealthCheckProgram=
InactiveLimit=0
KillWait=30
#MessageTimeout=10
#ResvOverRun=0
MinJobAge=300
#OverTimeLimit=0
SlurmctldTimeout=120
SlurmdTimeout=300
#UnkillableStepTimeout=60
#VSizeFactor=0
Waittime=0
# SCHEDULING
#DefMemPerCPU=0
FastSchedule=1
#MaxMemPerCPU=0
#SchedulerTimeSlice=30
SchedulerType=sched/backfill
SelectType=select/cons_res
SelectTypeParameters=CR_CPU
# JOB PRIORITY
#PriorityFlags=
#PriorityType=priority/basic
#PriorityDecayHalfLife=
#PriorityCalcPeriod=
#PriorityFavorSmall=
#PriorityMaxAge=
#PriorityUsageResetPeriod=
#PriorityWeightAge=
#PriorityWeightFairshare=
#PriorityWeightJobSize=
#PriorityWeightPartition=
#PriorityWeightQOS=
# LOGGING AND ACCOUNTING
#AccountingStorageEnforce=0
#AccountingStorageHost=
#AccountingStorageLoc=
#AccountingStoragePass=
#AccountingStoragePort=
AccountingStorageType=accounting_storage/none
#AccountingStorageUser=
AccountingStoreJobComment=YES
ClusterName=cluster
#DebugFlags=
#JobCompHost=
#JobCompLoc=
#JobCompPass=
#JobCompPort=
JobCompType=jobcomp/none
#JobCompUser=
#JobContainerType=job_container/none
JobAcctGatherFrequency=30
JobAcctGatherType=jobacct_gather/none
SlurmctldDebug=3
SlurmctldLogFile=/var/log/slurm-llnl/slurmctld.log
SlurmdDebug=3
SlurmdLogFile=/var/log/slurm-llnl/slurmd.log
#SlurmSchedLogFile=
#SlurmSchedLogLevel=
# POWER SAVE SUPPORT FOR IDLE NODES (optional)
#SuspendProgram=
#ResumeProgram=
#SuspendTimeout=
#ResumeTimeout=
#ResumeRate=
#SuspendExcNodes=
#SuspendExcParts=
#SuspendRate=
#SuspendTime=
# COMPUTE NODES
NodeName=Masternode NodeAddr=ip CPUs=4 State=UNKNOWN
NodeName=Node01 NodeAddr=ip CPUs=4 State=UNKNOWN
NodeName=Node02 NodeAddr=ip CPUs=4 State=UNKNOWN
NodeName=Node03 NodeAddr=ip CPUs=4 State=UNKNOWN
PartitionName=mycluster Nodes=Node[01-03] Default=YES MaxTime=INFINITE State=UP
drllama
Tue Jul 16, 2019 5:38 pm
One thing to double check is: What version of SLURM do you have installed?
Stretch has 16.X, whereas Buster has 18.X. slurm.conf has changed a fair bit between those two releases.
Grab a copy of the sample file in /usr/share/doc/slurm (uh, I think, going from memory here), and use it as the basis for your slurm.conf.
Cheers,
Bruce.
AZAZAZ
Tue Jul 16, 2019 5:59 pm
I currently have slurm version 18.08 installed. I looked for the slurm sample file, but cant find it. Are there any samples online?
drllama
Wed Jul 17, 2019 3:06 am
If you install from the repos, you should find the examples under /usr/share/doc/slurm*
I'd grab a copy for you, except I'm using 19.X now, compiled on my Pi's and on my big server which is acting as the controller.
Cheers,
Bruce.
Maphus
Sat Jul 20, 2019 4:39 am
I ran into the same problem with Buster and Slurm version 18.08. After looking at the log file, a solution that worked for me was changing the ProcktrackType to proctrack/linuxproc.
I hope this helps!
