Adri74100
Setting static IP address on a Pi 4
Mon Jul 08, 2019 2:45 pm
I would like to set a static IP address on a Raspberry pi 4.
Actually, the Pi is connected with Wifi and ethernet, both with DHCP.
I connect using Putty (SSH).
I tried "nano /etc/dhcpcd.conf" :
interface eth0
static ip_address=192.168.11.210/24
static routers=192.168.11.254
static domain_name_servers=192.168.11.254
After a reboot, "ip addr" shows :
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether dc:a6:32:00:62:ac brd ff:ff:ff:ff:ff:ff
    inet 192.168.11.33/24 brd 192.168.11.255 scope global noprefixroute eth0
    inet6 fe80::e4ec:8456:daf1:b7be/64 scope link
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether dc:a6:32:00:62:ad brd ff:ff:ff:ff:ff:ff
    inet 192.168.11.48/24 brd 192.168.11.255 scope global noprefixroute wlan0
    inet6 fe80::1f11:5fa:9945:f19b/64 scope link
And of course, the Pi isn't reachable with the 192.168.11.210 address.
Do you have any suggestions ?
epoch1970
Re: Setting static IP address on a Pi 4
Mon Jul 08, 2019 3:36 pm
Check the DHCP range of addresses that are managed by the DHCP server.
The static IP .210 you want for yourself must be outside the range. Otherwise the server might well refuse to comply with the request and give the client another address, like .33 here.
In fact, do the other way around:
- configure the DHCP server to identify the MAC address of the Pi and always give it .210, from the pool
- revert to standard configuration in dhcpcd.conf.
You'll have your fixed .210 address on your LAN, and on other networks the Pi will work without need for reconfiguration.
Adri74100
Mon Jul 08, 2019 3:46 pm
Hi, and thanks for your help.
Our DHCP range is from 192.168.11.1 to 99, but we are voluntarily setting the fixed IP addresses outside of this range. And we already have a lot of servers in that case (Windows).
So, I can't set a MAC binding for the .210 IP on the router, because this IP is outside of the DHCP range.
Maybe I should follow the second solution here, which involves disabling the DHCP client on the Pi ?
https://raspberrypi.stackexchange.com/q ... 4428#74428
epoch1970
Mon Jul 08, 2019 3:50 pm
Then it should work as is.
Check there isn't another machine using .210 on the network...
(You can do whatever you want on that machine, it is yours. But assuming the dhcp client does not work as it should and uninstalling it looks more inspired by hubris than logic.)
JohnSoCalUSA
Mon Jul 08, 2019 3:56 pm
Are you using Raspbian Buster?
I had a problem with dhcpcd crashing.
Try running dhcpcd from the command line and see what happens.
Adri74100
Mon Jul 08, 2019 4:00 pm
I tried to ping this IP and checked the router, I'm pretty sure it's unused (but I forgot to check that, you were right !).
I thought of uninstalling the DHCP client because you said "the server might well refuse to comply with the request", and I thought the DHCP client could interfere with the fixed IP address I configured in dhcpcd.conf.
So I won't proceed that way for now, and wait for other answers !
Adri74100
Mon Jul 08, 2019 4:03 pm
Yes, Raspbian Buster Lite.
dhcpcd returns
sending commands to master dhcpcd process
JohnSoCalUSA
Mon Jul 08, 2019 4:46 pm
dhcpcd returns
At least you did not get an error like I did.
You might want to try this command line to see if this works.
sudo dhcpcd -4 -S ip_address=192.168.11.210/24 \
-S routers=192.168.11.254 \
-S domain_name_servers=192.168.11.254 \
eth0
drgeoff
Mon Jul 08, 2019 6:17 pm
You did save dhcpcd.conf file before rebooting?
DirkS
Mon Jul 08, 2019 7:02 pm
+1
also make sure it was actually saved as you need admin rights to do that.
Adri74100
Tue Jul 09, 2019 6:33 am
dhcpcd returns
eth0
This command returns "sending commands to master dhcpcd process". And ip addr still shows another IP for eth0... even after a reboot.
For the others comments : yes I saved the file, and I connect as root. I'm used to configure some Debian web servers.
pcmanbob
Tue Jul 09, 2019 10:34 am
So first question, are you connecting to a standard domestic broadband router or is it a work or university network ?
what happens if you remove one of the connections to the network , having both wired and wireless connection to the same network may not be a good idea.
Adri74100
Tue Jul 09, 2019 10:50 am
Hi, and thanks for your help !
It is at work, the router is a Zyxel USG60.
I disabled the Wifi connection, but the Pi is still accesible at the .33 address :cry:
pcmanbob
Tue Jul 09, 2019 11:01 am
Then the first thing you should do it talk to the network admin to see if there is anything set on the router that prevents static IP addresses being set on a device.
if you had given us this information at the start you would have got this advice as the first response.
Adri74100
Tue Jul 09, 2019 11:29 am
As I already said : we already have a lot of servers in that case (with a fixed IP address, outside of the DHCP range).
However, I tried configuring my laptop to use this IP address, and I couldn't make it work.
So, the problem is probably not on the Raspberry side !
I contacted the network admin and will keep you informed.
Adri74100
Tue Jul 23, 2019 8:48 am
Hi everyone,
For the record : I tried with another IP address (.211 instead of .210) and everything worked fine !
So, the procedure mentionned in my first post is okay.
Thanks for your help.
Hcgrant
Wed Jul 31, 2019 3:29 pm
I also thought Buster was not letting me set a static ip .. but thanks to this I looked at the router and found that the ip was already in use!
So thanks :)
