asadeghime
Connecting four load cells to one amplifier
Wed Jun 26, 2019 8:47 pm
Hello All,
It is possible to connect four load cells [1] to one amplifier HX711?or I have to your one HX711 for each load cells?
Thank you very much for your help.
Best Regards
Alireza
[1] https://www.amazon.com/Platform-Scale-W ... 69&sr=8-15
drgeoff
Re: Connecting four load cells to one amplifier
Wed Jun 26, 2019 11:29 pm
Did you do any research? 30 seconds with Google found me https://www.sparkfun.com/products/13879 which answers your question.
davidcoton
Mon Jul 01, 2019 1:46 pm
https://cdn.sparkfun.com/datasheets/Sen ... nglish.pdf
HX711 has two inputs, but it seems impractical to use both simultaneously (different gains, awkward input selection).
So you probably need a separate HX711 for each cell.
Or Google "four channel load cell amplifier".
Signature retired
mahjongg
Mon Jul 01, 2019 3:42 pm
The answer to your question is NO!
If you carefully study the datasheet of the XH711 you can see this yourself almost immediately.
