deathguard12
Connecting E-Ink display to Raspberry Pi Zero
Wed Jun 26, 2019 5:00 pm
Is there a possibility of connecting ED060SCE (https://aliexpress.com/item/32802051655.html) to Raspberry Pi Zero. If yes, how to do that.
drgeoff
Re: Connecting E-Ink display to Raspberry Pi Zero
Wed Jun 26, 2019 6:56 pm
Almost certainly not possible to connect directly to a RPi. And finding/constructing what electronics you would need between the two is likely to be beyond anyone who needed to ask the question you asked. :(
Andyroo
Wed Jun 26, 2019 6:57 pm
Welcome to the forum.
Unfortunately this may work only if you can find an interface card from the cable to SPI.
It looks like the screen has the raw data connector and needs something like https://www.mikroe.com/eink-click to connect it to the Pi. You would then need to be able to write the control software and then the high level code to use it.
Note - I am not saying the above card will work with the screen. It is only as an example :D
