Fabulierer
Solder a RJ Connector on a raspberry pi zero?
Wed Jun 26, 2019 2:44 pm
Hello!
I am not really new to the raspberry pi, however I have never soldered before.
I am planning on making an FTP server with a raspberry pi zero, however, the rp0 doesnt have a LAN connection. So I found this: https://www.conrad.de/de/p/rj45-steckve ... 97238.html
and now I'm wondering if I can just solder it on the GPIO pins, and it will work, or if I have to use certain GPIO pins?
Thanks a lot :)
mahjongg
Re: Solder a RJ Connector on a raspberry pi zero?
Wed Jun 26, 2019 3:20 pm
An Ethernet interface doesn't exist of just a connector! :geek: :mrgreen:
You need a whole lot of electronics in-between the zero and the RJ-jack.
the easiest solution, in hardware, would probably be an USB-to-Ethernet adapter.
Another solution would be a smart Ethernet adapter with an SPI interface, and a RPI driver for it.
Wed Jun 26, 2019 3:28 pm
Hello!
Thanks a lot :)
Something like this ?
https://www.ebay.co.uk/itm/Add-extra-1- ... 3101530663
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
thagrol
Wed Jun 26, 2019 6:14 pm
Or this: https://raspi.tv/2015/ethernet-on-pi-ze ... on-your-pi
Don't expect much in the way of speed though.
This space unintentionally left blank.
alphanumeric
Wed Jun 26, 2019 7:36 pm
Plug and play and no soldering required.
https://shop.pimoroni.com/products/thre ... connector
