Carolyn28
NOOBS 3.1.1 & fake-hwclock needed?
Tue Jun 25, 2019 11:26 am
Do i need to install fake-hwclock if i use NOOBS 3.1.1?
B.Goode
Re: NOOBS 3.1.1 & fake-hwclock needed?
Tue Jun 25, 2019 11:31 am
NOOBS is an Installer.
Does it need accurate time information?
How would you modify it to use this module?
procount
Tue Jun 25, 2019 11:37 am
You cannot install anything in NOOBS. It is read-only.
If you connect it to the internet, it will get the current time from the RPF server in order to access https URLs.
Other than that it does not know or need to know the time.
Carolyn28
Tue Jun 25, 2019 12:09 pm
I was trying to say that do i need to install fake-hwclock if i use Raspbian Buster June 2019?
procount
Tue Jun 25, 2019 12:25 pm
No. It's already installed through systemd.
Type `systemctl` and you get a list of services including...
fake-hwclock.service   loaded    active exited    Restore / save the current clock
Carolyn28
Tue Jun 25, 2019 12:41 pm
OK Thanks. And that means it's fully working so no need to activate it?
procount
Tue Jun 25, 2019 12:57 pm
AFAIK
