corre
chromium - error message.
Wed Jun 19, 2019 1:44 pm
I have the raspberry with chromium set in kiosk mode.
After a power drop / oscillation, the raspberry turns on again but the chromium is displaying a small error message.
How can I remove this error message?
gkaiseril
Re: chromium - error message.
Wed Jun 19, 2019 1:48 pm
What is the exact message?
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
corre
Wed Jun 19, 2019 3:21 pm
B.Goode
Wed Jun 19, 2019 5:48 pm
If you choose either option, as appropriate to your needs, and then close the browser in a controlled fashion, doesn't it start cleanly the next time you try to use it?
corre
Wed Jun 26, 2019 1:27 pm
If I select one of the two options, it reopens the pages I've programmed. Then, if I close the browser in a controlled / correct way and restart raspberry, the pages open correctly and without displaying the message.
But if there is a new power interruption (causing unexpected shutdown), the message will be displayed again.
Is there a setting that will disable this message?
