hippy
[SOLVED] Shell script weirdness
Fri May 24, 2019 10:37 pm
I have a shell script "./work-sb" with execute set, a single "cd" command in it, but when I run it nothing happens. It's like it's just ignored. I have other one-liners, no shebangs, and they all work. The directory exists because I can type the same "cd" in at the command line ..
pi@Pi3B:~/extensions $ ls -l work-sb
-rwxr-xr-x 1 pi pi 43 May 24 23:25 work-sb
pi@Pi3B:~/extensions $ cat work-sb
cd /home/pi/sb-dev-cleanup/extensions/gpio
pi@Pi3B:~/extensions $ ./work-sb              <-- HERE !
pi@Pi3B:~/extensions $ cd /home/pi/sb-dev-cleanup/extensions/gpio
pi@Pi3B:~/sb-dev-cleanup/extensions/gpio $
Any ideas what's going on ? What I've done wrong ?
pcmanbob
Re: Shell script weirdness
Fri May 24, 2019 11:00 pm
Don't forget when you run a script you are not operating at the command line.
So your script is doing exactly what you told it to and changed the directory that it was working in, but you did not tell it to do anything else.
When you run the same cd command at the command line then you see the command line change the directory it's working in.
epoch1970
Fri May 24, 2019 11:03 pm
Do you expect that process to actually change the current directory of your terminal?
A process can change dir, but only for itself. Your code goes to a directory, and exits. It works, add an "ls" and see.
https://stackoverflow.com/questions/185 ... mmatically
If you want to create a shortcut command, you can define an alias (usually in your .profile), eg
me@lab:/tmp$ ls
tmp.iJWu9cp14U
me@lab:/tmp$ alias foo="mkdir $PWD/foo; cd foo"
me@lab:/tmp$ foo
me@lab:/tmp/foo$
scruss
Fri May 24, 2019 11:52 pm
Or do this:
. ./work-sb
‘.’ (a synonym for source) executes commands from a file in the current shell.
hippy
Sat May 25, 2019 12:05 am
I did! Too much switching between Windows and Linux too late at night .
I've gone with an "exec $SHELL" after the "cd" and an echoed reminder to type "exit" when done. I'm having enough trouble remembering which slashes, which command name, to have to remember it's dot-space for this particular script file.
I'd also been misled by an example I'd followed earlier which claimed it needed a "cd -" at the end to go back to where I was. Of course it doesn't.
Thanks for the help.
klricks
Sat May 25, 2019 12:11 am
You can use $SHELL
cd /home/pi/sb-dev-cleanup/extensions/gpio;$SHELL
Or to open a new terminal at a specified directory:
lxterminal --working-directory=/home/pi/sb-dev-cleanup/extensions/gpio;$SHELL
