buraks
RaspBerry Pi resize issue
Fri May 24, 2019 9:28 am
Hi everyone,
I created image from my 16 GB SD card and installed it on my 32 GB SD card. Now I cannot use my free 16 GB space. How can I merge?
df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 13G 12G 134M 99% /
devtmpfs 126M 0 126M 0% /dev
tmpfs 130M 0 130M 0% /dev/shm
tmpfs 130M 3.8M 127M 3% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 130M 0 130M 0% /sys/fs/cgroup
/dev/mmcblk0p6 68M 24M 45M 35% /boot
tmpfs 26M 4.0K 26M 1% /run/user/1000
/dev/mmcblk0p5 30M 397K 28M 2% /media/pi/SETTINGS2
sudo fdisk -uc /dev/mmcblk0
/dev/mmcblk0p1 8192 3291015 3282824 1.6G e W95 FAT16 (LBA)
/dev/mmcblk0p2 3291016 30449663 27158648 13G 5 Extended
/dev/mmcblk0p5 3293184 3358717 65534 32M 83 Linux
/dev/mmcblk0p6 3358720 3500031 141312 69M c W95 FAT32 (LBA)
/dev/mmcblk0p7 3506176 30449663 26943488 12.9G 83 Linux
I don't know which part should I need to delete and create new partition?
DarkPlatinum
Re: RaspBerry Pi resize issue
Fri May 24, 2019 12:09 pm
Use the expand file system function in Sudo raspi-config
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3 1 * Raspberry Pi 3B + :mrgreen:
Check Out My Raspberry Site (Run on a Raspberry Pi 3B :) ): Https://Html.dynu.net
Andyroo
Fri May 24, 2019 12:15 pm
If you want a bit more control or multiple partitions (though I would question why as the above is the simplest way to go) you could install gparted in the gui and use that.
buraks
Fri May 24, 2019 5:54 pm
Thank you it is excellent application.
As you see in the image, how can I resize the mmcblk0p7?
I cannot unmount it. It gives error as "Could not unmount /dev/mmcblk0p7 most likely other partitions are also mounted...".
Andyroo
Fri May 24, 2019 6:05 pm
Best thing is to use another copy of Raspbian and mount this card in a SD to USB adapter and do it that way after making a backup of course.
buraks
Fri May 24, 2019 6:13 pm
Thank you very much I did it exactly you said. It worked like a charm.
Andyroo
Fri May 24, 2019 7:15 pm
No probs - gparted has saved me lots of time in the last few years.
Its normally one of the first programs I load on a new box.
