I am interested in making a gear indicator for a bicycle.
The rear derailleur is not visible.
Can the Raspberry pi measure the rate of the pedal and wheel rotation and calculate the chain positioning (assuming that there is no overlap in the ratios)?
It will need to be able to keep track of pulses from two inputs and do maths at the same time.
Thanks for reading.
Cheers!
