Tue Mar 05, 2019 10:34 pm
niska wrote: ↑Tue Mar 05, 2019 9:25 pm
I'm planning on adding
one external HDD to my RPi. I read some guides saying that HDD needs external power source. But other say that if you have a good power source then external power source is not needed if only using one HDD.
I'm currently using a IKEA KOPPLA power supply 5V 2.4A with a short no name cable. Will this supply one Seagate Expansion Portable Drive 2TB (powered by USB)?
If I instead buy the official RPi power source, would it supply one Seagate Expansion Portable Drive 2TB?
A quick search of "IKEA KOPPLA" showed several devices that are (multi-output) USB
chargers which, in general, are
not the same as a proper power
supply in that a ('phone) charger, even if labeled 5V 2.4A, is not required to (and probably won't) provide 5V when 2.4A is being drawn - the voltage is likely to be ~4V , just above the (discharged) voltage of the battery they're intended to charge. FWIW, and to illustrate what is required of a true power supply, see my measurements of the two variations of the official power supply here:
http://www.cpmspectrepi.uk/raspberry_pi ... _Models.29
W.r.t. the "Seagate Expansion Portable Drive 2TB (powered by USB)" w/o details of the (maximum) current it can draw and which model of Pi you have no-one can easily comment further.
Trev.
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, A+ and a B2) but Buster on the P4B's. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
