RDK
tmux command and options
Fri Feb 08, 2019 1:12 am
I'm using the following command in my rc.local to start a Python script/program in a tmux window. Just looking at the manual and the web, I'm trying to figure out how it works?
su xxx -c "tmux new-session -s XDR -d '/usr/bin/python /mnt/usbdrive/pgms/yyyy.py; exec bash'"
I've been using this for some time and must have gotten help from someone on the web, but my memory has failed me!! The first part "tmux new-session -s XDR " I understand => create a new window with the name XDR.
I can't find the "-d" option in the documentation, but I'm guessing it directs that the following code in single quotes is to be started in a bash window.
What I really want in pointed to somewhere that I can find all of this documented. Thanks....RDK
bertlea
Re: tmux command and options
Fri Feb 08, 2019 1:31 am
The official document should be the man page of the tmux command. Try use the command:
man tmux
in your terminal.
That "-d" is described in the man page: "The new session is attached to the current terminal unless -d is given...."
There are many cheat-sheets or non-official documents on tmux if you just google it.
