clovel
MySQL
Wed Jan 02, 2019 10:29 pm
Hi !
I’m quite new to this, and I need help.
I’m trying to install MySQL on my Raspberry Pi B 3+. I followed several tutorials, but I can’t seem to make this work. I can install mysql correctly with apt, but I cant reset the root password. Each time I try to, I cant log back in...
Can tou guys help fill in the gaps ? This is what I tried (other than the usual « set password » commands)
sudo mysql_secure_installation
OR
Reseting the password w/
sudo mysqld_safe --skip-grant-tables --skip-networking &
Each time I can set the password but I cannot log back in (as I said earlier).
Thanks,
Clovel
PS : Sorry if this is not enough, I may update later when I ger to my laptop...
fbe
Re: MySQL
Thu Jan 03, 2019 5:55 pm
If you didn't do anything else than you described, everything still should be fine. The root user even should have a password. The "problem" is, that it isn't used for authentication.
Try
sudo mysql
to login (the server should run "normally" without "--skip-grant-tables").
If that works, create an alternative administrator account
create user 'admin'@'localhost' identified by 'secret';
grant all privileges on *.* to 'admin'@'localhost' with grant option;
exit
(replace secret by a good password).
Now login as admin
mysql -uadmin -p
When tutorials ask for "root" use "admin" until you know, why the password for root is not used and what things will break, if you make MariaDB using password authentication for root.
Return to “Beginners”
