KevinA
Arrow and Del keys not working
Wed Jan 02, 2019 3:51 am
For two new Users I added, every time I press an arrowkey I get newlines with A, B, C and D's, Del key ^[[3~, but the PI user everything is good.
Is there a script to download all the extras from the complete Raspbian Stretch? I need a way to add uses that works.
fbe
Re: Arrow and Del keys not working
Wed Jan 02, 2019 5:10 pm
Please check what login shell is configured for the user. If you didn't specify it when creating the user, the default should be /bin/sh. Check the output of
echo $0
in a terminal or on the console. If you don't see "bash" type
bash
and everything should be fine - unless you leave the bash with
exit
To use bash as login shell for the current user, type
chsh -s /bin/bash
You are asked for the password of the current user then. Logout, login, enjoy.
KevinA
Thu Jan 03, 2019 5:10 am
It was the bash thing, I created the users with webmin, I needed to build a template directory with the defaults for users. No more cursing the keyboard setting... Thanks
