Savage_Hams
Root Password For Sudo?
Sun Dec 30, 2018 12:25 am
Hi all,
New to Raspberry Pi and just started using a 3. Was doing some config changes through cli and noticed sudo commands don't ask for the root pwd. Feeling insecure (haha), I set a root password. However, using the default pi user, I'm still not prompted for root password when using sudo or even switching to the root user. This feels....wrong.
Is there a reason Jessie doesn't prompt for root password when root privileges are needed? Feels like a security hole and I can't get it to prompt for a password to root.
Thanks!
scruss
Re: Root Password For Sudo?
Sun Dec 30, 2018 2:47 am
here's how to have sudo prompt you for a password: viewtopic.php?t=169212#p1087078
It's not the root password, but your own. Regular users shouldn't know the root password.
Also, jessie is an old Raspbian distribution. Use Stretch.
klricks
Sun Dec 30, 2018 5:08 am
Hi all,
Thanks!
All versions of Raspbian by design/ default have root password disabled, passwordless sudo and auto login to user pi without password.
IMO not necessary to change that unless running a server with open ports on the router.
A while back a nag pop up message was added if ssh is enabled AND the password has not been changed from the default: raspberry
JamesPi123
Sun Dec 30, 2018 6:46 am
sudo bash
then
passwd root
Savage_Hams
Sun Dec 30, 2018 6:54 pm
Thanks all! It's really not a big deal but was curious potential risks from it and wanted to see what the community thought. The ease of getting into root is counter to all my previous Linux knowledge.
mfa298
Sun Dec 30, 2018 7:56 pm
Based on the link in the first reply to this thread (2nd post) you can edit (or just remove) the file /etc/sudoers.d/010_pi-nopasswd which will result in sudo prompting for the users password. With the standard rules sudo can only be used like that by users in the sudo group (which pi is). You can also write custom sudo rules which allow certain users (or groups) to only run certain commands as another user (it doesn't just have to be root).
There are various arguments about whether sudo or su provides the best security. Both have their merits and drawbacks.
