biker67
errors at run time under auto start
Sun Dec 09, 2018 10:30 pm
This code is the product of all my previous post and runs without error using "run module". Most recently I have been hungup on getting auto start to function at boot. With the URL listed below , I think that start at boot is possible. There is a problem however. A raspberry pi post is the source of the most help concerning auto start. It is executable (anyone can run it 3X under permissions tab).
https://www.raspberrypi-spy.co.uk/2015/ ... y-pi-boot/
The errors listed on the terminal screen are in the IMAGE attached. I have no idea how to reproduce those same errors. When the program is in IDLE ,DEBUG is not an option.
see bottom for image.
The "autorun" doesn't like line 7, turtle.setup("799, 479")
objects to FILE <"string"> in line 6, etc....
[code #!/usr/bin/python3
import turtle
from turtle import *
import tkinter as tk
import time, random
import RPi.GPIO as GPIO
turtle.setup(799,479)
# --- functions --- (lower_case_names)
def main():
global red, blue, green, pink, orange, cyan, grey, yellow
global acolor, equip, txtcolor, wirepos, fun1, fun2, status, height, width
global color, w, t, Choice
equip="back"
red = 5
blue = 25
green = 23
pink = 6
orange = 17
cyan = 13
grey = 16
yellow = 12
status = 1
height = 150.0 # now it is float
width = height * .75
width = round(width, 2)
def initGPIO():
out_putslist = ['5','25','23','6','17','13','16','12']
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO.setup(5,GPIO.OUT,initial=1)
GPIO.setup(25,GPIO.OUT,initial=1)
GPIO.setup(23,GPIO.OUT,initial=1)
GPIO.setup(6,GPIO.OUT,initial=1)
GPIO.setup(17,GPIO.OUT,initial=1)
GPIO.setup(13,GPIO.OUT,initial=1)
GPIO.setup(16,GPIO.OUT,initial=1)
GPIO.setup(12,GPIO.OUT,initial=1)
initGPIO()
rect_list = [(-350,190,-330,140,0,0,"red","black","HORN"," ",5,1),
(-200,190,-190,140,-190,120,"blue","aquamarine","NAVAGA","LIGHTS",25,1),
(50,190,60,140,60,120,"green","black","COCKPIT","LIGHTS",23,1),
(200,190,220,140,220,120,"pink","black","T-TOP","LIGHTS",6,1),
(-350,-50,-330,-100,-330,-120,"orange","black","BILGE","PUMP",17,1),
(-200,-50,-180,-100,-180,-120,"cyan","black","WASH","DOWN",13,1),
(50,-50,70,-100,70,-120,"grey","black","FRONT","WELL",16,1),
(200,-50,220,-100,220,-120,"yellow","black","BACK","WELL",12,1)]
def draw_rect(x1, y1, width, height, color):
y1 = -y1
print(x1, y1)
canvas = turtle.getcanvas()
canvas.create_rectangle((x1, y1, x1+width, y1+height), fill=color, width=0)
def draw_it(): # draws one colored square with lables
turtle.penup()
turtle.goto(x2,y2)
if color == "blue":
turtle.color("aquamarine")
turtle.write(fun1,font=('Arial', 14, 'normal'))
turtle.goto(x3,y3)
turtle.write(fun2,font=('Arial', 14, 'normal'))
if color == "blue":
turtle.color("black")
turtle.penup()
return
def all_off():
print("shit1")
for [x1,y1,x2,y2,x3,y3,color,txtcolor,fun1,fun2,wirepos,status] in rect_list:
w = (x1)
t = (y1+10)
channel = int(wirepos)
status = 1
print(channel, status)
GPIO.output(channel,status) # set channel to high
print(Choice)
x1 = w; y1 = t; width = 112; height = 10
color = ("white")
print("\033[4\033[J")
def get_pixel_color(x, y):
# canvas use different coordinates
y = -y
ids = canvas.find_overlapping(x, y, x, y)
if ids: # if list is not empty
index = ids[-1]
color = canvas.itemcget(index, "fill")
if color != '':
return color.lower()
return "white" # default color
def modify_global_variables(rawx,rawy):
global xclick
global yclick
global equip
global acolor
global w, t, Choice
w = 0
t = 0
xclick = int(rawx)
yclick = int(rawy)
Choice = (get_pixel_color(xclick, yclick)) # color of square touched
if Choice == "black":
return
if Choice == "darkred": # KILL SWITCH
print(Choice)
all_off()
if Choice == "aquamarine":
return
if Choice == "white":
x1=-225; y1=20; width=450; height=50 # cleanup verify zone
color="white"
return
for x1,y1,x2,y2,x3,y3,color,txtcolor,fun1,fun2,wirepos,status in rect_list:
if Choice in [x1,y1,x2,y2,x3,y3,color,txtcolor,fun1,fun2,wirepos,status]:
x1=-225; y1=20; width=400; height=50
color = "white"
#turtle.pendown()
draw_rect(x1, y1, width, height, color) # on / off rectangle erased
x1=-225; y1=20; width=200; height=50
color = "red2"
x1=-25; y1=20; width=50; height=50
color = Choice;
x1 = 25; y1 = 20; width=200; height=50
color = "green2"
color = "black"
turtle.goto(-160,-20)
turtle.write("OFF", font=('arial', 16, 'normal'))
turtle.goto(160,-20)
turtle.write("ON", font=('arial', 16, 'normal'))
turtle.goto(-60,-20)
turtle.write(fun1, font=('arial', 14, 'normal'))
equip = fun1
acolor = Choice # color of function clicked on
return
if Choice == "green2": # on means light goes off!
#turn on/off gadgets
if acolor in [x1,y1,x2,y2,x3,y3,color,txtcolor,fun1,fun2,wirepos,status]:
w = (x1)
t = (y1+10)
channel= int(wirepos)
status = 0
function_on_off()
if Choice == "red2": # off means light comes on!
w = (x1)
t = (y1+10)
status = 1
function_on_off()
return
def function_on_off():
color = "black"
color = "magenta"
x1=w; y1=t; width=112; height=10
turtle.goto(0,0)
color = ("white")
turtle.pendown()
color = ("black")
turtle.penup()
return
# --- main ---# Global variables specifying the point clicked
xclick = 0
yclick = 0
wirepos=0
# Draw rectangles
width = 100
# Use tkinter.Canvas to draw rectangle
turtle.hideturtle()
draw_it() # main loop rectangle draw 1st x
turtle.goto(-20,180)
turtle.pendown()
turtle.pensize(10)
turtle.color("darkred")
circle(15)
turtle.penup()
turtle.goto(-40,140)
turtle.write("KILL",font=('Arial', 16, 'normal'))
# Gets the click & Modifies the global variables
turtle.onscreenclick(modify_global_variables)
turtle.done()
#main program logic
if __name__ == '__main__':
main()
][/code]
a snapshot of RPi problems_resized.jpg (49.62 KiB) Viewed 149 times
biker67
Re: errors at run time under auto start
Mon Dec 10, 2018 3:37 am
here is a picture perfect example of a copied program (one of many) that runs in python 3.7.1 BUT at the same time is generating red ink on the shell page; meaning it probably will not run from autostart; in the same manner that my program runs from "run Module" but hangs up if asked to auto run.
Is this the best one can expect? I realize I know very little about python but I haven't stumbled on anything yet because why ...? I don't know the answer.
import turtle
painter = turtle.Turtle()
painter.pencolor("blue")
for i in range(50):
    painter.forward(50)
    painter.left(123) # Let's go counterclockwise this time
painter.pencolor("red")
for i in range(50):
    painter.forward(100)
    painter.left(123)
turtle.done()
DirkS
Mon Dec 10, 2018 8:20 am
Please repair your code blocks. It looks like you managed to delete some brackets...
And also post your error message(s) as text, also in a code block
biker67
Mon Dec 10, 2018 2:32 pm
This are the errors produced by the copied exmpleary from above. My plan was to grab a perfect program and run it thorough the auto start process to prove that it can be done.
=============== RESTART: /home/pi/mypigraphics/monday_temp.py ===============
  File "/home/pi/mypigraphics/monday_temp.py", line 9, in <module>
  File "/usr/lib/python3.5/turtle.py", line 1699, in left
    self._rotate(angle)
  File "/usr/lib/python3.5/turtle.py", line 3276, in _rotate
    self._update()
  File "/usr/lib/python3.5/turtle.py", line 2660, in _update
    self._update_data()
  File "/usr/lib/python3.5/turtle.py", line 2646, in _update_data
    self.screen._incrementudc()
  File "/usr/lib/python3.5/turtle.py", line 1292, in _incrementudc
    raise Terminator
turtle.Terminator
topguy
Fri Dec 14, 2018 9:20 am
The error "No display name and no $DISPLAY variable set" just confirms what I said in the other thread. TkInter needs a running X-server.
