David Ryan
Switch between AP and Client mode on Raspbian Stretch/Raspberry PI B+
Thu Sep 06, 2018 9:31 pm
Hello all,
I've found a few resources on this topic, but I've yet to find a solid solution.
I was able to get into AP mode using this tutorial; however, I was never able to get the supplied IP addresses to work properly. My connected devices were all getting 169.*.*.* addresses. I suspect the problem came from improper traffic forwarding/iptable rules because I recognize this address as a link local.
I also struggled a bit getting it back to client mode. I was able to do so, however the link local address problem still persists and the client I'm trying to connect to denies me.
After I get that all sorted it would be ideal if I could flip between these modes with a script similar to this answer .
For what it's worth once I get the scripting taken care of I will be using Node to handle the switching.
I appreciate the help guys. Thanks in advance.
epoch1970
Re: Switch between AP and Client mode on Raspbian Stretch/Raspberry PI B+
Sat Sep 08, 2018 11:03 am
Please peruse the official documentation to setup an AP: https://www.raspberrypi.org/documentati ... s-point.md
This page describes 2 configs: 1st part a routed AP (different network for wifi than ethernet, dhcp/dns provided by Pi), 2nd part a bridged AP (wifi and ethernet on the same network, dhcp/dns provided by router).
Once you have the AP running, switching from client "STA" mode to AP mode should be a matter of:
- starting / stopping services: hostapd (+dnsmasq) started for AP, wpa_supplicant started for STA (dhcpcd starts it for you)
- make dhcpcd understand which configuration it should use for the wifi interface. I don't know how this is done. With "profiles"?
- remove iptables rules used in AP mode when switching to STA, if any.
