How to open navit from kodi?
Posted: Tue Jul 24, 2018 10:13 am
by EasyComp Zeeland
Hi there,
as I mentioned before in previous posts, I'm building a CarPI on Raspbian using Kodi and Navit;
as theme for kodi I use carpi, which has a navigation button to open navit from kodi, but what code do I need to insert to make it work and overlay kodi in the button it's settings?
It works fine but thats the last step!
Re: How to open navit from kodi?
Posted: Tue Jul 24, 2018 2:28 pm
by Rascas
Where did you download that skin? If it has a button to open Navit, I think it is better to ask directly to the respective skin developer.
Posted: Tue Jul 24, 2018 4:21 pm
by EasyComp Zeeland
just downloaded it somewhere from the internet. From someone who isn't the developer.
Posted: Thu Jul 26, 2018 11:56 am
by EasyComp Zeeland
Still waiting for an answer?
Posted: Fri Jul 27, 2018 2:06 pm
by topguy
I'm not even sure how to read this sentence correctly.. can you expand a bit about exactly what setting you are talking about and what you mean with "code"..
Refering us to another (unlinked) thread for background info is not that polite either..
Posted: Sun Jul 29, 2018 8:57 am
by EasyComp Zeeland
I forgot to paste that url but I meant this post; viewtopic.php?f=73&t=217472&p=1346519#p1346519
here is some more info about the sentence you didn't quite get
What do I need to insert here (video) to make Navit run?!
https://easycompzeeland.nl/site/assets/ ... .53.49.mp4
Thanks!
Posted: Mon Jul 30, 2018 12:43 pm
by topguy
Have you installed "navit" on the Pi ?
Posted: Mon Jul 30, 2018 3:59 pm
by EasyComp Zeeland
Yes and it works fine! but just doesn't open from kodi.
Posted: Tue Jul 31, 2018 1:48 pm
by topguy
How would you start "navit" outside of Kodi ?
In a terminal if you write the command "which navit" you will probably get the response "/usr/bin/navit" or something similar which is the full path to the "navit" executable. You might try to enter that full path into the field in Kodi.
Posted: Thu Aug 02, 2018 2:49 pm
by EasyComp Zeeland
I already tried that method but it doesn't work...
Posted: Thu Aug 02, 2018 10:50 pm
by Rascas
Like I said above, I am not familiar with that skin and navit but I am pretty sure that you cannot run any other graphical program on the RPi while Kodi is running. Well, you can start it, but you will only see it when you exit Kodi.
So the script you are looking for must:
1- Exit Kodi
2- Start Navit
3- Start Kodi again when you exit Navit
If you contact the skin developer, he probably has or knows some script for that.
Posted: Sat Aug 04, 2018 2:41 pm
by EasyComp Zeeland
Now I've created;
import os
import xbmc
#activate GPS USB Dongle
os.system("sudo systemctl stop gpsd.socket")
os.system("sudo systemctl disable gpsd.socket")
os.system("sudo gpsd /dev/ttyUSB0 -F /var/run/gpsd.sock")
#open navit
os.system("navit")
It works although how to minimize kodi so navit can be on top of it?
Posted: Sat Aug 04, 2018 3:46 pm
by DirkS
Well, that's the problem as Rascas already identified.
Video output of Kodi on the Pi uses hardware acceleration and output is sent (more or less) directly to the hardware; it bypasses the framebuffer.
There's nothing to minimize. You would have to quit Kodi or maybe it's possible to 'switch off' Kodi output.
Posted: Sat Aug 04, 2018 4:33 pm
by Rascas
Now I've created;
import os
import xbmc
#open navit
os.system("navit")
You can't minimize Kodi, it is rendered in an overlay on the framebuffer. You have to close it and open it again when you exit navit.
Posted: Sat Aug 04, 2018 5:34 pm
by EasyComp Zeeland
Now I've created;
import os
import xbmc
#open navit
os.system("navit")
Hmm, wondering if there is a workaround!
Posted: Sun Aug 05, 2018 2:33 am
by Rascas
Try this:
-Create a bash script with the following:
#!/bin/bash
sudo killall -9 kodi.bin
navit
kodi &
-Change the last line of your python script by this:
os.system("bash /path/to/the/script/scriptname")
Other solution would be to compile Kodi yourself with support for X server and OpenGL, but it will be much slower and without video decoding acceleration.
Posted: Sun Aug 05, 2018 6:50 pm
by EasyComp Zeeland
Try this:
#!/bin/bash
navit
kodi &
I created this now it seems to do something at least, it doesn't kill kodi but It suddenly restarts kodi when I'll exit navit, I can control navit from vnc ;) not from my 7" pi screen which got kodi on it.
import os
import xbmc
#activate GPS dongle
os.system("bash /home/pi/.kodi/addons/skin.CarPc-Carbon/scripts/ActiveerGPS.sh")
#run navit
os.system("navit")
#kill kodi and comeback when navit gets killed
os.system("bash /home/pi/.kodi/addons/skin.CarPc-Carbon/scripts/minimizekodi.sh")
Main .py script
Code to activate GPS dongle - ActiveerGPS.sh
#!/bin/bash
navit
kodi &
Kill kodi and comeback script - Minimizekodi.sh
Posted: Sun Aug 05, 2018 7:53 pm
by Rascas
If it is a RPi 2 or 3, it is:
sudo killall kodi_v7.bin
Posted: Mon Aug 06, 2018 9:52 am
by EasyComp Zeeland
it seems completely ignored, kodi doesn't get killed..
Posted: Mon Aug 06, 2018 10:06 am
by Rascas
Check the processes running with top or something. I can kill Kodi here just fine via ssh with that.
Posted: Mon Aug 06, 2018 11:25 am
by EasyComp Zeeland
Well I can kill it with ssh as well but the script doesn't seem to work..
Posted: Mon Aug 13, 2018 5:27 pm
by EasyComp Zeeland
Any Response please?
Posted: Mon Aug 13, 2018 5:47 pm
by Rascas
Try without -9, try to debug that by yourself, add some echos/printfs to a file, on both python and bash scripts, try to launch navit first and kill kodi after, I don't know... You already know what you have to do, try different approaches to do the same.
Posted: Sat Oct 13, 2018 6:03 pm
by Rojit K Johncy
Try this:
#!/bin/bash
navit
kodi &
import os
import xbmc
#run navit
os.system("navit")
Main .py script
#!/bin/bash
navit
kodi &
I am very new to Raspberry Pi and Kodi. I need your help in getting called Navit from Kodi. Can you please provide step by step procedure how to call Navit from Kodi? The python script works fine from RPi terminal but i dont understand how i should call Navit from Kodi.. Need your help plss..
