mugurdi
I can not start motion as daemon
Thu Jul 19, 2018 5:06 am
I have motion installed with a picamera. If I start motion from the console, it's fine. but I can not configure it as a daemon.
I enabled motion to run as a daemon, editing "/etc/default/motion" file and setting
start_motion_daemon = yes
I enabled motion by the command:
sudo systemctl enable motiom
And I get an error: "Failed to enable unit: File motion.service: No such file or directory"
I've been with this for several days. What else can I do?
lmarmisa
Re: I can not start motion as daemon
Thu Jul 19, 2018 8:54 am
Why did you type the command?:
This command is not necessary.
You should enable the daemon simply by changing this line of the file /etc/default/motion:
# set to 'yes' to enable the motion daemon
start_motion_daemon=yes
The command systemctl status motion will show the status of motion running as service:
pi@rpi:~ $ systemctl status motion
● motion.service - LSB: Start Motion detection
   Loaded: loaded (/etc/init.d/motion; generated; vendor preset: enabled)
   Active: active (running) since Thu 2018-07-19 10:24:37 CEST; 28min ago
     Docs: man:systemd-sysv-generator(8)
  Process: 328 ExecStart=/etc/init.d/motion start (code=exited, status=0/SUCCESS)
   CGroup: /system.slice/motion.service
           └─561 /usr/bin/motion
Thu Jul 19, 2018 5:14 pm
Since it's still using the old sysvinit stuff you need to run
sudo update-rc.d motion defaults
sudo update-rc.d motion enable
that should get it running a boot time.
This is a doctor free zone.
mugurdi
Fri Jul 20, 2018 3:06 am
Thank you very much for your responses.
Imarmisa: in file/etc/default/motion I have written "start_motion_daemon = yes"
But when executing
The answer is
: Unit motion.service could not be found.
DougieLawson: I executed the following and this has been the answer:
There's no answer. It seems that everything is fine
update-rc.d: error: can not find a LSB script for motion
How can I solve this error?
mugurdi
Sat Jul 21, 2018 4:50 am
I have permission problems. what should I do? Change permissions to the /var/run/ folder? What permissions should I put?
[0:motion] [NTC] [ALL] [Jul 20 16:45:14] become_daemon: Motion going to daemon mode
[0:motion] [ERR] [ALL] [Jul 20 16:45:14] create_path: Problem creating directory /var/run/motion: Permission denied
[0:motion] [EMG] [ALL] [Jul 20 16:45:14] become_daemon: Exit motion, cannot create process id file (pid file) /var/run/motion/motion.pid: Permission denied
lmarmisa
Sat Jul 21, 2018 7:52 am
I have checked here that the file /etc/default/motion should not include any blank space character. If motion detects a syntax error (blank space), the daemon is not started.
This is the correct syntax, not yours:
mugurdi
Sun Jul 22, 2018 3:06 am
Thanks, lmarmisa
the blank spaces are introduced by the Google translator when some text with non-alphanumeric characters is pasted in the source window ... I forgot to correct it. In fact, the syntax is fine in the motion file.
My problem is the permissions. How can I avoid "problem creating directory /var/run/motion: Permission denied" and "can not create process id file (pid file) /var/run/motion/motion.pid: Permission denied"
mugurdi
Sun Jul 22, 2018 3:45 am
If in the console I type
:~ $ motion
the two errors happen
If I type
:~ $ sudo motion
the program starts normally.
lmarmisa
Sun Jul 22, 2018 8:05 am
:~ $ motion
If I type
:~ $ sudo motion
This behavior is good. The user pi has no privileges for running motion but root is able to run that program.
If the syntax of start_motion_daemon=yes is correct, simply reboot your system and check if motion is really running as daemon. Type the command ps -ef | grep motion:
pi@rpi5:~ $ ps -ef | grep motion
motion     608     1  2 09:56 ?        00:00:06 /usr/bin/motion
pi        1219  1193  0 10:00 pts/1    00:00:00 grep --color=auto motion
pi@rpi5:~ $
In the previous example, /usr/bin/motion is running as user motion and process 608.
If the command does not show /usr/bin/motion, take a look at the file /var/log/syslog:
tail -n 100 /var/log/syslog
mugurdi
Mon Jul 23, 2018 5:07 am
I rebooted (no motion started)
pi 1259 1210 0 06:54 pts/1 00:00:00 grep --color=auto motion
$ tail -n 100 /var/log/syslog
Jul 23 06:34:11 raspberrypi bluetoothd[676]: sap-server: Operation not permitted (1)
Jul 23 06:34:11 raspberrypi bluetoothd[676]: Endpoint registered: sender=:1.11 path=/A2DP/SBC/Source/1
Jul 23 06:34:11 raspberrypi bluetoothd[676]: Endpoint registered: sender=:1.11 path=/A2DP/SBC/Sink/1
Jul 23 06:34:11 raspberrypi systemd[1]: Starting Hostname Service...
Jul 23 06:34:11 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
Jul 23 06:34:11 raspberrypi kernel: [ 9.924340] Bluetooth: RFCOMM TTY layer initialized
Jul 23 06:34:11 raspberrypi kernel: [ 9.924361] Bluetooth: RFCOMM socket layer initialized
Jul 23 06:34:11 raspberrypi kernel: [ 9.924386] Bluetooth: RFCOMM ver 1.11
Jul 23 06:34:11 raspberrypi dbus-daemon[582]: Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service'
Jul 23 06:34:11 raspberrypi systemd[504]: Starting Virtual filesystem service...
Jul 23 06:34:11 raspberrypi dbus[323]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jul 23 06:34:11 raspberrypi systemd[1]: Started Hostname Service.
Jul 23 06:34:11 raspberrypi systemd[1]: Startup finished in 1.445s (kernel) + 8.777s (userspace) = 10.223s.
Jul 23 06:34:11 raspberrypi dbus-daemon[582]: Successfully activated service 'org.gtk.vfs.Daemon'
Jul 23 06:34:11 raspberrypi systemd[504]: Started Virtual filesystem service.
Jul 23 06:34:11 raspberrypi kernel: [ 10.409034] fuse init (API version 7.26)
Jul 23 06:34:11 raspberrypi systemd[1]: Mounting FUSE Control File System...
Jul 23 06:34:11 raspberrypi systemd[1]: Mounted FUSE Control File System.
Jul 23 06:34:12 raspberrypi dbus[323]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service'
Jul 23 06:34:12 raspberrypi systemd[1]: Starting Authorization Manager...
Jul 23 06:34:12 raspberrypi dhcpcd[352]: wlan0: using static address 192.168.1.19/24
Jul 23 06:34:12 raspberrypi avahi-daemon[310]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.1.19.
Jul 23 06:34:12 raspberrypi dhcpcd[352]: wlan0: adding route to 192.168.1.0/24
Jul 23 06:34:12 raspberrypi dhcpcd[352]: wlan0: adding default route via 192.168.1.1
Jul 23 06:34:12 raspberrypi avahi-daemon[310]: New relevant interface wlan0.IPv4 for mDNS.
Jul 23 06:34:12 raspberrypi avahi-daemon[310]: Registering new address record for 192.168.1.19 on wlan0.IPv4.
Jul 23 06:34:12 raspberrypi polkitd[792]: started daemon version 0.105 using authority implementation `local' version `0.105'
Jul 23 06:34:12 raspberrypi dbus[323]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Jul 23 06:34:12 raspberrypi systemd[1]: Started Authorization Manager.
Jul 23 06:34:12 raspberrypi dbus-daemon[582]: Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service'
Jul 23 06:34:12 raspberrypi systemd[504]: Starting Virtual filesystem service - disk device monitor...
Jul 23 06:34:12 raspberrypi dbus[323]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service'
Jul 23 06:34:12 raspberrypi systemd[1]: Starting Disk Manager...
Jul 23 06:34:13 raspberrypi udisksd[884]: udisks daemon version 2.1.8 starting
Jul 23 06:34:13 raspberrypi dbus[323]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Jul 23 06:34:13 raspberrypi systemd[1]: Started Disk Manager.
Jul 23 06:34:13 raspberrypi udisksd[884]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Jul 23 06:34:13 raspberrypi udisksd[884]: Cleaning up mount point /media/pi/SETTINGS (device 179:5 is not mounted)
Jul 23 06:34:13 raspberrypi dbus-daemon[582]: Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
Jul 23 06:34:13 raspberrypi systemd[504]: Started Virtual filesystem service - disk device monitor.
Jul 23 06:34:13 raspberrypi dbus-daemon[582]: Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service'
Jul 23 06:34:13 raspberrypi systemd[504]: Starting Virtual filesystem service - digital camera monitor...
Jul 23 06:34:13 raspberrypi dbus-daemon[582]: Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
Jul 23 06:34:13 raspberrypi systemd[504]: Started Virtual filesystem service - digital camera monitor.
Jul 23 06:34:13 raspberrypi dbus-daemon[582]: Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service'
Jul 23 06:34:13 raspberrypi systemd[504]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
Jul 23 06:34:13 raspberrypi dbus-daemon[582]: Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
Jul 23 06:34:13 raspberrypi systemd[504]: Started Virtual filesystem service - Media Transfer Protocol monitor.
Jul 23 06:34:13 raspberrypi dbus-daemon[582]: Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service'
Jul 23 06:34:13 raspberrypi systemd[504]: Starting Virtual filesystem service - GNOME Online Accounts monitor...
Jul 23 06:34:13 raspberrypi dbus-daemon[582]: Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor'
Jul 23 06:34:13 raspberrypi systemd[504]: Started Virtual filesystem service - GNOME Online Accounts monitor.
Jul 23 06:34:13 raspberrypi dbus-daemon[582]: Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service'
Jul 23 06:34:13 raspberrypi systemd[504]: Starting Virtual filesystem service - Apple File Conduit monitor...
Jul 23 06:34:13 raspberrypi gvfs-afc-volume-monitor[933]: Volume monitor alive
Jul 23 06:34:13 raspberrypi dbus-daemon[582]: Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
Jul 23 06:34:13 raspberrypi systemd[504]: Started Virtual filesystem service - Apple File Conduit monitor.
Jul 23 06:34:14 raspberrypi kernel: [ 13.318124] random: crng init done
Jul 23 06:34:14 raspberrypi kernel: [ 13.318136] random: 7 urandom warning(s) missed due to ratelimiting
Jul 23 06:34:15 raspberrypi kernel: [ 14.156181] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
Jul 23 06:34:15 raspberrypi udisksd[884]: Mounted /dev/mmcblk0p5 at /media/pi/SETTINGS on behalf of uid 1000
Jul 23 06:34:20 raspberrypi dhcpcd[352]: wlan0: no IPv6 Routers available
Jul 23 06:34:58 raspberrypi systemd[1]: Time has been changed
Jul 23 06:34:58 raspberrypi systemd[504]: Time has been changed
Jul 23 06:34:58 raspberrypi systemd-timesyncd[286]: Synchronized to time server 193.145.15.15:123 (2.debian.pool.ntp.org).
Jul 23 06:34:58 raspberrypi systemd[1]: apt-daily.timer: Adding 44min 43.034771s random time.
Jul 23 06:34:58 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 18min 5.823990s random time.
Jul 23 06:35:20 raspberrypi kernel: [ 57.045933] w1_master_driver w1_bus_master1: Attaching one wire slave 00.800000000000 crc 8c
Jul 23 06:35:20 raspberrypi kernel: [ 57.049169] w1_master_driver w1_bus_master1: Family 0 for 00.800000000000.8c is not registered.
Jul 23 06:36:23 raspberrypi kernel: [ 120.635296] w1_master_driver w1_bus_master1: Attaching one wire slave 00.400000000000 crc 46
Jul 23 06:36:23 raspberrypi kernel: [ 120.638132] w1_master_driver w1_bus_master1: Family 0 for 00.400000000000.46 is not registered.
Jul 23 06:37:14 raspberrypi kernel: [ 171.394523] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c00000000000 crc ca
Jul 23 06:37:14 raspberrypi kernel: [ 171.397314] w1_master_driver w1_bus_master1: Family 0 for 00.c00000000000.ca is not registered.
Jul 23 06:38:31 raspberrypi kernel: [ 247.832927] w1_master_driver w1_bus_master1: Attaching one wire slave 00.200000000000 crc 23
Jul 23 06:38:31 raspberrypi kernel: [ 247.835754] w1_master_driver w1_bus_master1: Family 0 for 00.200000000000.23 is not registered.
Jul 23 06:39:34 raspberrypi kernel: [ 311.432382] w1_master_driver w1_bus_master1: Attaching one wire slave 00.a00000000000 crc af
Jul 23 06:39:34 raspberrypi kernel: [ 311.435274] w1_master_driver w1_bus_master1: Family 0 for 00.a00000000000.af is not registered.
Jul 23 06:40:12 raspberrypi kernel: [ 349.352580] w1_master_driver w1_bus_master1: Attaching one wire slave 00.600000000000 crc 65
Jul 23 06:40:12 raspberrypi kernel: [ 349.357523] w1_master_driver w1_bus_master1: Family 0 for 00.600000000000.65 is not registered.
Jul 23 06:40:53 raspberrypi kernel: [ 389.842322] w1_master_driver w1_bus_master1: Attaching one wire slave 00.e00000000000 crc e9
Jul 23 06:40:53 raspberrypi kernel: [ 389.847090] w1_master_driver w1_bus_master1: Family 0 for 00.e00000000000.e9 is not registered.
Jul 23 06:41:56 raspberrypi kernel: [ 452.831429] w1_master_driver w1_bus_master1: Attaching one wire slave 00.100000000000 crc 9d
Jul 23 06:41:56 raspberrypi kernel: [ 452.834190] w1_master_driver w1_bus_master1: Family 0 for 00.100000000000.9d is not registered.
Jul 23 06:42:35 raspberrypi kernel: [ 491.951167] w1_master_driver w1_bus_master1: Attaching one wire slave 00.900000000000 crc 11
Jul 23 06:42:35 raspberrypi kernel: [ 491.953911] w1_master_driver w1_bus_master1: Family 0 for 00.900000000000.11 is not registered.
Jul 23 06:43:50 raspberrypi kernel: [ 567.193298] w1_master_driver w1_bus_master1: Attaching one wire slave 00.500000000000 crc db
Jul 23 06:43:50 raspberrypi kernel: [ 567.196256] w1_master_driver w1_bus_master1: Family 0 for 00.500000000000.db is not registered.
Jul 23 06:44:42 raspberrypi kernel: [ 619.155313] w1_master_driver w1_bus_master1: Attaching one wire slave 00.d00000000000 crc 57
Jul 23 06:44:42 raspberrypi kernel: [ 619.160102] w1_master_driver w1_bus_master1: Family 0 for 00.d00000000000.57 is not registered.
Jul 23 06:45:08 raspberrypi kernel: [ 645.595450] w1_master_driver w1_bus_master1: Attaching one wire slave 00.300000000000 crc be
Jul 23 06:45:08 raspberrypi kernel: [ 645.598333] w1_master_driver w1_bus_master1: Family 0 for 00.300000000000.be is not registered.
Jul 23 06:45:08 raspberrypi systemd[1]: Reached target Network is Online.
Jul 23 06:45:08 raspberrypi systemd[1]: Starting Daily apt download activities...
Jul 23 06:45:11 raspberrypi systemd[1]: Started Daily apt download activities.
Jul 23 06:45:11 raspberrypi systemd[1]: apt-daily.timer: Adding 9h 54min 56.907510s random time.
Jul 23 06:45:11 raspberrypi systemd[1]: apt-daily.timer: Adding 9h 53min 4.350699s random time.
Jul 23 06:45:58 raspberrypi kernel: [ 694.996280] w1_master_driver w1_bus_master1: Attaching one wire slave 00.b00000000000 crc 32
Jul 23 06:45:58 raspberrypi kernel: [ 694.999028] w1_master_driver w1_bus_master1: Family 0 for 00.b00000000000.32 is not registered.
Jul 23 06:46:37 raspberrypi kernel: [ 734.276723] w1_master_driver w1_bus_master1: Attaching one wire slave 00.700000000000 crc f8
Jul 23 06:46:37 raspberrypi kernel: [ 734.279426] w1_master_driver w1_bus_master1: Family 0 for 00.700000000000.f8 is not registered.
pi@raspberrypi:/var/log $
lmarmisa
Mon Jul 23, 2018 7:54 am
Your system started at 06:34:01 (Jul 23 06:34:11 raspberrypi kernel: [ 9.924340] Bluetooth: RFCOMM TTY layer initialized) but the first event shown on syslog shows the time 06:34:11 (Jul 23 06:34:11 raspberrypi bluetoothd[676]: sap-server: Operation not permitted (1)). No luck. One hundred lines were too few. :(
This procedure will work much better.
First, of all, remove the current file /var/log/syslog and reboot your system:
sudo rm /var/log/syslog
sudo reboot
Once the system is restarted, type this command:
grep motion /var/log/syslog
This the output in my case (I suppose that yours will be different):
pi@rpi5:~ $ grep motion /var/log/syslog
Jul 23 09:19:24 rpi5 motion[365]: Starting motion detection daemon: motion.
Jul 23 09:19:29 rpi5 motion: [0:motion] [NTC] [ALL] conf_load: Processing thread 0 - config file /etc/motion/motion.conf
Jul 23 09:19:29 rpi5 motion: [0:motion] [ALR] [ALL] conf_cmdparse: Unknown config option "ffmpeg_deinterlace"
Jul 23 09:19:29 rpi5 motion: [0:motion] [ALR] [ALL] conf_cmdparse: Unknown config option "sdl_threadnr"
Jul 23 09:19:29 rpi5 motion: [0:motion] [NTC] [ALL] motion_startup: Motion 4.0 Started
Jul 23 09:19:29 rpi5 motion: [0:motion] [NTC] [ALL] motion_startup: Logging to syslog
Jul 23 09:19:29 rpi5 motion: [0:motion] [NTC] [ALL] motion_startup: Using log type (ALL) log level (NTC)
Jul 23 09:19:29 rpi5 motion: [0:motion] [NTC] [ALL] become_daemon: Motion going to daemon mode
Jul 23 09:19:29 rpi5 motion: [0:motion] [NTC] [ALL] become_daemon: Created process id file /var/run/motion/motion.pid. Process ID is 542
Jul 23 09:19:29 rpi5 motion: [0:motion] [NTC] [ALL] motion_startup: Motion running as daemon process
Jul 23 09:19:29 rpi5 motion: [0:motion] [NTC] [ENC] ffmpeg_init: ffmpeg libavcodec version 57.48.101 libavformat version 57.41.100
Jul 23 09:19:30 rpi5 motion: [0:motion] [NTC] [ALL] main: Camera 0 is from /etc/motion/motion.conf
Jul 23 09:19:30 rpi5 motion: [0:motion] [NTC] [ALL] main: Camera 0 is device: /dev/video0 input -1
Jul 23 09:19:30 rpi5 motion: [0:motion] [NTC] [ALL] main: Stream port 8081
Jul 23 09:19:30 rpi5 motion: [0:motion] [NTC] [ALL] main: Waiting for threads to finish, pid: 542
Jul 23 09:19:30 rpi5 motion: [1:ml1] [NTC] [ALL] motion_init: Camera 0 started: motion detection Enabled
Jul 23 09:19:30 rpi5 motion: [0:web_control] [NTC] [STR] http_bindsock: listening on any IPv4 address port 8080
Jul 23 09:19:30 rpi5 motion: [1:ml1] [NTC] [VID] vid_v4lx_start: Using videodevice /dev/video0 and input -1
Jul 23 09:19:30 rpi5 motion: [0:web_control] [NTC] [STR] httpd_run: Started motion-httpd server on port 8080 (auth Disabled)
Jul 23 09:19:31 rpi5 motion: [1:ml1] [NTC] [VID] v4l2_get_capability: #012------------------------#012cap.driver: "uvcvideo"#012cap.card: "UVC Camera (046d:081
b)"#012cap.bus_info: "usb-3f980000.usb-1.1.3"#012cap.capabilities=0x84200001#012------------------------
Jul 23 09:19:31 rpi5 motion: [1:ml1] [NTC] [VID] v4l2_get_capability: - VIDEO_CAPTURE
Jul 23 09:19:31 rpi5 motion: [1:ml1] [NTC] [VID] v4l2_get_capability: - STREAMING
Motion was started only 1 second after the first kernel event shown in the log file.
mugurdi
Tue Jul 24, 2018 2:49 am
I do not understand anything...
I have done what you suggest: I have deleted /var/log/syslog and I have done reboot
Then with grep motion /var/log/syslog no line comes out, and the new syslog has about 600 lines.
I think this file is correct
mugurdi
Tue Jul 24, 2018 2:55 am
I think that in /etc/motion/motion.conf configuration file everything is fine:
# Daemon
# Start in daemon (background) mode and release terminal (default: off)
daemon on
# File to store the process ID, also called pid file. (default: not defined)
process_id_file /var/run/motion/motion.pid
# Basic Setup Mode
# Start in Setup-Mode, daemon disabled. (default: off)
setup_mode off
# Use a file to save logs messages, if not defined stderr and syslog is used. (default: not defined)
logfile /var/log/motion/motion.log
lmarmisa
Tue Jul 24, 2018 5:07 am
We are looking in a wrong file (/var/log/syslog).
According to your configuration the log file is /var/log/motion/motion.log.
Take a look at this file in order to find information about the error.
BTW, this is my file /etc/motion/motion.conf:
# Rename this distribution example file to motion.conf
# This config file was generated by motion 3.2.12+git20140228
# Daemon
daemon on
# Basic Setup Mode
setup_mode off
# logfile /var/log/motion/motion.log
# Level of log messages [1..9] (EMR, ALR, CRT, ERR, WRN, NTC, INF, DBG, ALL). (default: 6 / NTC)
log_level 6
# Filter to log messages by type (COR, STR, ENC, NET, DBL, EVT, TRK, VID, ALL). (default: ALL)
log_type all
# Capture device options
# Videodevice to be used for capturing  (default /dev/video0)
# for FreeBSD default is /dev/bktr0
# v4l2_palette allows to choose preferable palette to be use by motion
# to capture from those supported by your videodevice. (default: 17)
# E.g. if your videodevice supports both V4L2_PIX_FMT_SBGGR8 and
# V4L2_PIX_FMT_MJPEG then motion will by default use V4L2_PIX_FMT_MJPEG.
# Setting v4l2_palette to 2 forces motion to use V4L2_PIX_FMT_SBGGR8
# instead.
# Values :
# V4L2_PIX_FMT_SN9C10X : 0  'S910'
# V4L2_PIX_FMT_SBGGR16 : 1  'BYR2'
# V4L2_PIX_FMT_SBGGR8  : 2  'BA81'
# V4L2_PIX_FMT_SPCA561 : 3  'S561'
# V4L2_PIX_FMT_SGBRG8  : 4  'GBRG'
# V4L2_PIX_FMT_SGRBG8  : 5  'GRBG'
# V4L2_PIX_FMT_PAC207  : 6  'P207'
# V4L2_PIX_FMT_PJPG    : 7  'PJPG'
# V4L2_PIX_FMT_MJPEG   : 8  'MJPEG'
# V4L2_PIX_FMT_JPEG    : 9  'JPEG'
# V4L2_PIX_FMT_RGB24   : 10 'RGB3'
# V4L2_PIX_FMT_SPCA501 : 11 'S501'
# V4L2_PIX_FMT_SPCA505 : 12 'S505'
# V4L2_PIX_FMT_SPCA508 : 13 'S508'
# V4L2_PIX_FMT_UYVY    : 14 'UYVY'
# V4L2_PIX_FMT_YUYV    : 15 'YUYV'
# V4L2_PIX_FMT_YUV422P : 16 '422P'
# V4L2_PIX_FMT_YUV420  : 17 'YU12'
v4l2_palette 17
# Tuner device to be used for capturing using tuner as source (default /dev/tuner0)
# This is ONLY used for FreeBSD. Leave it commented out for Linux
; tunerdevice /dev/tuner0
# The video input to be used (default: -1)
# Should normally be set to 0 or 1 for video/TV cards, and -1 for USB cameras
input -1
# The video norm to use (only for video capture and TV tuner cards)
# Values: 0 (PAL), 1 (NTSC), 2 (SECAM), 3 (PAL NC no colour). Default: 0 (PAL)
norm 0
# The frequency to set the tuner to (kHz) (only for TV tuner cards) (default: 0)
frequency 0
# Rotate image this number of degrees. The rotation affects all saved images as
# well as movies. Valid values: 0 (default = no rotation), 90, 180 and 270.
rotate 0
# Image width (pixels). Valid range: Camera dependent, default: 352
width 1024
# Image height (pixels). Valid range: Camera dependent, default: 288
height 768
# Maximum number of frames to be captured per second.
# Valid range: 2-100. Default: 100 (almost no limit).
framerate 2
# Minimum time in seconds between capturing picture frames from the camera.
# Default: 0 = disabled - the capture rate is given by the camera framerate.
# This option is used when you want to capture images at a rate lower than 2 per second.
minimum_frame_time 5
# URL to use if you are using a network camera, size will be autodetected (incl http:// ftp:// mjpg:// rstp:// or file:///)
# Must be a URL that returns single jpeg pictures or a raw mjpeg stream. Default: Not defined
; netcam_url value
# Username and password for network camera (only if required). Default: not defined
# Syntax is user:password
; netcam_userpass value
# The setting for keep-alive of network socket, should improve performance on compatible net cameras.
# off:   The historical implementation using HTTP/1.0, closing the socket after each http request.
# force: Use HTTP/1.0 requests with keep alive header to reuse the same connection.
# on:    Use HTTP/1.1 requests that support keep alive as default.
# Default: off
netcam_keepalive off
# URL to use for a netcam proxy server, if required, e.g. "http://myproxy".
# If a port number other than 80 is needed, use "http://myproxy:1234".
# Default: not defined
; netcam_proxy value
# Set less strict jpeg checks for network cameras with a poor/buggy firmware.
# Default: off
netcam_tolerant_check off
# Let motion regulate the brightness of a video device (default: off).
# The auto_brightness feature uses the brightness option as its target value.
# If brightness is zero auto_brightness will adjust to average brightness value 128.
# Only recommended for cameras without auto brightness
auto_brightness off
# Set the initial brightness of a video device.
# If auto_brightness is enabled, this value defines the average brightness level
# which Motion will try and adjust to.
# Valid range 0-255, default 0 = disabled
brightness 0
# Set the contrast of a video device.
contrast 0
# Set the saturation of a video device.
saturation 0
# Set the hue of a video device (NTSC feature).
hue 0
# Round Robin (multiple inputs on same video device name)
# Number of frames to capture in each roundrobin step (default: 1)
roundrobin_frames 1
# Number of frames to skip before each roundrobin step (default: 1)
roundrobin_skip 1
# Try to filter out noise generated by roundrobin (default: off)
switchfilter off
# Motion Detection Settings:
# Threshold for number of changed pixels in an image that
# triggers motion detection (default: 1500)
threshold 1500
# Automatically tune the threshold down if possible (default: off)
threshold_tune off
# Noise threshold for the motion detection (default: 32)
noise_level 32
# Automatically tune the noise threshold (default: on)
noise_tune on
# Despeckle motion image using (e)rode or (d)ilate or (l)abel (Default: not defined)
# Recommended value is EedDl. Any combination (and number of) of E, e, d, and D is valid.
# (l)abeling must only be used once and the 'l' must be the last letter.
# Comment out to disable
despeckle_filter EedDl
# Detect motion in predefined areas (1 - 9). Areas are numbered like that:  1 2 3
# A script (on_area_detected) is started immediately when motion is         4 5 6
# detected in one of the given areas, but only once during an event.        7 8 9
# One or more areas can be specified with this option. Take care: This option
# does NOT restrict detection to these areas! (Default: not defined)
; area_detect value
# PGM file to use as a sensitivity mask.
# Full path name to. (Default: not defined)
; mask_file value
# Dynamically create a mask file during operation (default: 0)
# Adjust speed of mask changes from 0 (off) to 10 (fast)
smart_mask_speed 0
# Ignore sudden massive light intensity changes given as a percentage of the picture
# area that changed intensity. Valid range: 0 - 100 , default: 0 = disabled
lightswitch 0
# Picture frames must contain motion at least the specified number of frames
# in a row before they are detected as true motion. At the default of 1, all
# motion is detected. Valid range: 1 to thousands, recommended 1-5
minimum_motion_frames 1
# Specifies the number of pre-captured (buffered) pictures from before motion
# was detected that will be output at motion detection.
# Recommended range: 0 to 5 (default: 0)
# Do not use large values! Large values will cause Motion to skip video frames and
# cause unsmooth movies. To smooth movies use larger values of post_capture instead.
pre_capture 0
# Number of frames to capture after motion is no longer detected (default: 0)
post_capture 0
# Event Gap is the seconds of no motion detection that triggers the end of an event.
# An event is defined as a series of motion images taken within a short timeframe.
# Recommended value is 60 seconds (Default). The value -1 is allowed and disables
# events causing all Motion to be written to one single movie file and no pre_capture.
# If set to 0, motion is running in gapless mode. Movies don't have gaps anymore. An
# event ends right after no more motion is detected and post_capture is over.
event_gap 60
# Maximum length in seconds of a movie
# When value is exceeded a new movie file is created. (Default: 0 = infinite)
max_movie_time 10
# Always save images even if there was no motion (default: off)
emulate_motion off
# Image File Output
# Output 'normal' pictures when motion is detected (default: on)
# Valid values: on, off, first, best, center
# When set to 'first', only the first picture of an event is saved.
# Picture with most motion of an event is saved when set to 'best'.
# Picture with motion nearest center of picture is saved when set to 'center'.
# Can be used as preview shot for the corresponding movie.
output_pictures off
# Output pictures with only the pixels moving object (ghost images) (default: off)
output_debug_pictures off
# The quality (in percent) to be used by the jpeg compression (default: 75)
quality 75
# Type of output images
# Valid values: jpeg, ppm (default: jpeg)
picture_type jpeg
# FFMPEG related options
# Film (movies) file output, and deinterlacing of the video input
# The options movie_filename and timelapse_filename are also used
# by the ffmpeg feature
# Use ffmpeg to encode movies in realtime (default: off)
ffmpeg_output_movies on
# Use ffmpeg to make movies with only the pixels moving
# object (ghost images) (default: off)
ffmpeg_output_debug_movies off
# Use ffmpeg to encode a timelapse movie
# Default value 0 = off - else save frame every Nth second
ffmpeg_timelapse 0
# The file rollover mode of the timelapse video
# Valid values: hourly, daily (default), weekly-sunday, weekly-monday, monthly, manual
ffmpeg_timelapse_mode daily
# Bitrate to be used by the ffmpeg encoder (default: 400000)
# This option is ignored if ffmpeg_variable_bitrate is not 0 (disabled)
ffmpeg_bps 500000
# Enables and defines variable bitrate for the ffmpeg encoder.
# ffmpeg_bps is ignored if variable bitrate is enabled.
# Valid values: 0 (default) = fixed bitrate defined by ffmpeg_bps,
# or the range 2 - 31 where 2 means best quality and 31 is worst.
ffmpeg_variable_bitrate 0
# Codec to used by ffmpeg for the video compression.
# Timelapse mpegs are always made in mpeg1 format independent from this option.
# Supported formats are: mpeg1 (ffmpeg-0.4.8 only), mpeg4 (default), and msmpeg4.
# mpeg1 - gives you files with extension .mpg
# mpeg4 or msmpeg4 - gives you files with extension .avi
# msmpeg4 is recommended for use with Windows Media Player because
# it requires no installation of codec on the Windows client.
# swf - gives you a flash film with extension .swf
# flv - gives you a flash video with extension .flv
# ffv1 - FF video codec 1 for Lossless Encoding ( experimental )
# mov - QuickTime ( testing )
# ogg - Ogg/Theora ( testing )
ffmpeg_video_codec mpeg4
# Use ffmpeg to deinterlace video. Necessary if you use an analog camera
# and see horizontal combing on moving objects in video or pictures.
# (default: off)
ffmpeg_deinterlace off
# SDL Window
# Number of motion thread to show in SDL Window (default: 0 = disabled)
sdl_threadnr 0
# External pipe to video encoder
# Replacement for FFMPEG builtin encoder for ffmpeg_output_movies only.
# Bool to enable or disable extpipe (default: off)
use_extpipe off
# External program (full path and opts) to pipe raw video to
# Generally, use '-' for STDIN...
;extpipe mencoder -demuxer rawvideo -rawvideo w=320:h=240:i420 -ovc x264 -x264encopts bframes=4:frameref=1:subq=1:scenecut=-1:nob_adapt:threads=1:keyint=1000:8x8dct:vbv_bufsize=4000:crf=24:partitions=i8x8,i4x4:vbv_maxrate=800:no-chroma-me -vf denoise3d=16:12:48:4,pp=lb -of   avi -o %f.avi - -fps %fps
# Snapshots (Traditional Periodic Webcam File Output)
# Make automated snapshot every N seconds (default: 0 = disabled)
snapshot_interval 0
# Text Display
# %Y = year, %m = month, %d = date,
# %H = hour, %M = minute, %S = second, %T = HH:MM:SS,
# %v = event, %q = frame number, %t = thread (camera) number,
# %D = changed pixels, %N = noise level, \n = new line,
# %i and %J = width and height of motion area,
# %K and %L = X and Y coordinates of motion center
# %C = value defined by text_event - do not use with text_event!
# You can put quotation marks around the text to allow
# leading spaces
# Locate and draw a box around the moving object.
# Valid values: on, off, preview (default: off)
# Set to 'preview' will only draw a box in preview_shot pictures.
locate_motion_mode off
# Set the look and style of the locate box if enabled.
# Valid values: box, redbox, cross, redcross (default: box)
# Set to 'box' will draw the traditional box.
# Set to 'redbox' will draw a red box.
# Set to 'cross' will draw a little cross to mark center.
# Set to 'redcross' will draw a little red cross to mark center.
locate_motion_style box
# Draws the timestamp using same options as C function strftime(3)
# Default: %Y-%m-%d\n%T = date in ISO format and time in 24 hour clock
# Text is placed in lower right corner
text_right %Y-%m-%d\n%T
# Draw a user defined text on the images using same options as C function strftime(3)
# Default: Not defined = no text
# Text is placed in lower left corner
; text_left CAMERA %t
# Draw the number of changed pixed on the images (default: off)
# Will normally be set to off except when you setup and adjust the motion settings
# Text is placed in upper right corner
text_changes off
# This option defines the value of the special event conversion specifier %C
# You can use any conversion specifier in this option except %C. Date and time
# values are from the timestamp of the first image in the current event.
# Default: %Y%m%d%H%M%S
# The idea is that %C can be used filenames and text_left/right for creating
# a unique identifier for each event.
text_event %Y%m%d%H%M%S
# Draw characters at twice normal size on images. (default: off)
text_double on
# Text to include in a JPEG EXIF comment
# May be any text, including conversion specifiers.
# The EXIF timestamp is included independent of this text.
;exif_text %i%J/%K%L
# Target Directories and filenames For Images And Films
# For the options snapshot_, picture_, movie_ and timelapse_filename
# you can use conversion specifiers
# Quotation marks round string are allowed.
# Target base directory for pictures and films
# Recommended to use absolute path. (Default: current working directory)
target_dir /tmp/motion
# File path for snapshots (jpeg or ppm) relative to target_dir
# Default: %v-%Y%m%d%H%M%S-snapshot
# Default value is equivalent to legacy oldlayout option
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-snapshot
# File extension .jpg or .ppm is automatically added so do not include this.
# Note: A symbolic link called lastsnap.jpg created in the target_dir will always
# point to the latest snapshot, unless snapshot_filename is exactly 'lastsnap'
snapshot_filename %v-%Y%m%d%H%M%S-snapshot
# File path for motion triggered images (jpeg or ppm) relative to target_dir
# Default: %v-%Y%m%d%H%M%S-%q
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-%q
# Set to 'preview' together with best-preview feature enables special naming
# convention for preview shots. See motion guide for details
picture_filename %v-%Y%m%d%H%M%S-%q
# File path for motion triggered ffmpeg films (movies) relative to target_dir
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H%M%S
# File extension .mpg or .avi is automatically added so do not include this
# This option was previously called ffmpeg_filename
movie_filename %v-%Y%m%d%H%M%S
# File path for timelapse movies relative to target_dir
# Default: %Y%m%d-timelapse
# Default value is near equivalent to legacy oldlayout option
# For Motion 3.0 compatible mode choose: %Y/%m/%d-timelapse
# File extension .mpg is automatically added so do not include this
timelapse_filename %Y%m%d-timelapse
# Global Network Options
# Enable or disable IPV6 for http control and stream (default: off )
ipv6_enabled off
# Live Stream Server
# The mini-http server listens to this port for requests (default: 0 = disabled)
stream_port 8081
# Quality of the jpeg (in percent) images produced (default: 50)
stream_quality 50
# Output frames at 1 fps when no motion is detected and increase to the
# rate given by stream_maxrate when motion is detected (default: off)
stream_motion off
# Maximum framerate for stream streams (default: 1)
stream_maxrate 1
# Restrict stream connections to localhost only (default: on)
stream_localhost off
# Limits the number of images per connection (default: 0 = unlimited)
# Number can be defined by multiplying actual stream rate by desired number of seconds
# Actual stream rate is the smallest of the numbers framerate and stream_maxrate
stream_limit 0
# Set the authentication method (default: 0)
# 0 = disabled
# 1 = Basic authentication
# 2 = MD5 digest (the safer authentication)
stream_auth_method 0
# Authentication for the stream. Syntax username:password
# Default: not defined (Disabled)
; stream_authentication username:password
# HTTP Based Control
# TCP/IP port for the http server to listen on (default: 0 = disabled)
webcontrol_port 8080
# Restrict control connections to localhost only (default: on)
webcontrol_localhost off
# Output for http server, select off to choose raw text plain (default: on)
webcontrol_html_output on
# Authentication for the http based control. Syntax username:password
; webcontrol_authentication username:password
# Tracking (Pan/Tilt)
# Type of tracker (0=none (default), 1=stepper, 2=iomojo, 3=pwc, 4=generic, 5=uvcvideo, 6=servo)
# The generic type enables the definition of motion center and motion size to
# be used with the conversion specifiers for options like on_motion_detected
track_type 0
# Enable auto tracking (default: off)
track_auto off
# Serial port of motor (default: none)
;track_port /dev/ttyS0
# Motor number for x-axis (default: 0)
;track_motorx 0
# Set motorx reverse (default: 0)
;track_motorx_reverse 0
# Motor number for y-axis (default: 0)
;track_motory 1
# Set motory reverse (default: 0)
;track_motory_reverse 0
# Maximum value on x-axis (default: 0)
;track_maxx 200
# Minimum value on x-axis (default: 0)
;track_minx 50
# Maximum value on y-axis (default: 0)
;track_maxy 200
# Minimum value on y-axis (default: 0)
;track_miny 50
# Center value on x-axis (default: 0)
;track_homex 128
# Center value on y-axis (default: 0)
;track_homey 128
# ID of an iomojo camera if used (default: 0)
track_iomojo_id 0
# Angle in degrees the camera moves per step on the X-axis
# with auto-track (default: 10)
# Currently only used with pwc type cameras
track_step_angle_x 10
# Angle in degrees the camera moves per step on the Y-axis
track_step_angle_y 10
# Delay to wait for after tracking movement as number
# of picture frames (default: 10)
track_move_wait 10
# Speed to set the motor to (stepper motor option) (default: 255)
track_speed 255
# Number of steps to make (stepper motor option) (default: 40)
track_stepsize 40
# External Commands, Warnings and Logging:
# You can use conversion specifiers for the on_xxxx commands
# %f = filename with full path
# %n = number indicating filetype
# Both %f and %n are only defined for on_picture_save,
# on_movie_start and on_movie_end
# Do not sound beeps when detecting motion (default: on)
# Note: Motion never beeps when running in daemon mode.
quiet on
# Command to be executed when an event starts. (default: none)
# An event starts at first motion detected after a period of no motion defined by event_gap
; on_event_start value
# Command to be executed when an event ends after a period of no motion
# (default: none). The period of no motion is defined by option event_gap.
; on_event_end value
# Command to be executed when a picture (.ppm|.jpg) is saved (default: none)
# To give the filename as an argument to a command append it with %f
; on_picture_save value
# Command to be executed when a motion frame is detected (default: none)
; on_motion_detected value
# Command to be executed when motion in a predefined area is detected
# Check option 'area_detect'.   (default: none)
; on_area_detected value
# Command to be executed when a movie file (.mpg|.avi) is created. (default: none)
; on_movie_start value
# Command to be executed when a movie file (.mpg|.avi) is closed. (default: none)
; on_movie_end value
# Command to be executed when a camera can't be opened or if it is lost
# NOTE: There is situations when motion don't detect a lost camera!
# It depends on the driver, some drivers dosn't detect a lost camera at all
# Some hangs the motion thread. Some even hangs the PC! (default: none)
; on_camera_lost value
# Common Options for database features.
# Options require database options to be active also.
# Log to the database when creating motion triggered picture file  (default: on)
; sql_log_picture on
# Log to the database when creating a snapshot image file (default: on)
; sql_log_snapshot on
# Log to the database when creating motion triggered movie file (default: off)
; sql_log_movie off
# Log to the database when creating timelapse movies file (default: off)
; sql_log_timelapse off
# SQL query string that is sent to the database
# Use same conversion specifiers has for text features
# Additional special conversion specifiers are
# %n = the number representing the file_type
# Default value:
# Create tables :
# Mysql
# CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time_stamp timestamp(14), event_time_stamp timestamp(14));
# Postgresql
# CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time_stamp timestamp without time zone, event_time_stamp timestamp without time zone);
# insert into security(camera, filename, frame, file_type, time_stamp, text_event) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
; sql_query insert into security(camera, filename, frame, file_type, time_stamp, event_time_stamp) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
# Database Options
# database type : mysql, postgresql, sqlite3 (default : not defined)
; database_type value
# database to log to (default: not defined)
; database_dbname value
# The host on which the database is located (default: localhost)
; database_host value
# User account name for database (default: not defined)
; database_user value
# User password for database (default: not defined)
; database_password value
# Port on which the database is located
#  mysql 3306 , postgresql 5432 (default: not defined)
; database_port value
# Database Options For SQLite3
# SQLite3 database (file path) (default: not defined)
; sqlite3_db value
# Video Loopback Device (vloopback project)
# Output images to a video4linux loopback device
# The value '-' means next available (default: not defined)
; video_pipe value
# Output motion images to a video4linux loopback device
; motion_video_pipe value
# Thread config files - One for each camera.
# Except if only one camera - You only need this config file.
# If you have more than one camera you MUST define one thread
# config file for each camera in addition to this config file.
# Remember: If you have more than one camera you must have one
# thread file for each camera. E.g. 2 cameras requires 3 files:
# This motion.conf file AND thread1.conf and thread2.conf.
# Only put the options that are unique to each camera in the
# thread config files.
; thread /etc/motion/thread1.conf
; thread /etc/motion/thread2.conf
; thread /etc/motion/thread3.conf
; thread /etc/motion/thread4.conf
I made some changes and had to install the package ffmpeg:
sudo apt-get install ffmpeg
mugurdi
Wed Jul 25, 2018 4:29 am
I deleted /var/log/motion/motion.log, I made reboot and no file called motion.log is created.
I'm thinking about reinstalling everything: in addition to motion what should I reinstall: ffmpeg? More things?
I appreciate your help, because I'm lost.
Metonics
Wed Feb 13, 2019 9:54 pm
did you ever get this to work?
I seem to have the same issue - have tried all combinations of setting motion.conf etc but always get status: active(exited)
The software used to work fine several months ago!
mugurdi
Sun Feb 17, 2019 7:07 am
I continue with my problem:
A) In /etc/default/motion file is set daemon yes
B) To avoid problems of permissions, I have executed:
sudo chown motion:motion /var/run/motion
sudo chown motion:motion /var/log/motion
sudo chown motion:motion /var/lib/motion
C) I have deleted the log file that was very large, I have done reboot
sudo reboot
D) Then I have executed this command
grep motion  var/log/syslog
There is no line, that is, motion has not started.
E) I have executed
sudo motion
Feb 17 07:28:33 raspberrypi motion: [0: motion] [NTC] [ALL] conf_load: Processing thread 0 - config file /etc/motion/motion.conf
Feb 17 07:28:33 raspberrypi motion: [0: motion] [ALR] [ALL] conf_cmdparse: Unknown config option "widht"
Feb 17 07:28:33 raspberrypi motion: [0: motion] [NTC] [ALL] config_camera: Processing camera config file /etc/motion/camera0.conf
Feb 17 07:28:33 raspberrypi motion: [0: motion] [NTC] [ALL] motion_startup: Motion 4.0 Started
Feb 17 07:28:33 raspberrypi motion: [0: motion] [NTC] [ALL] motion_startup: Logging to file (/var/log/motion/motion.log)
It does not work as a service:
sudo service motion status
But there is an instance running
root      1172     1  1 07:28 ?        00:00:30 motion
pi        1545  1250  0 07:54 pts/0    00:00:00 grep --color=auto motion
My wish is that motion be initiated as a service
What else can I do?
I appreciate your kindness
Metonics
Tue Feb 19, 2019 11:17 am
It seems you have the same issue as me. Motion used to work with both a USB camera and the pi camera but now I cannot get it to work at all!
I made all the changes to motion, motion.conf etc but no success
have you been able to run motion as a non-daemon? This does not seem to work for me either
geg58
Wed Feb 20, 2019 1:34 am
to fix this please do the following:
 sudo nano /etc/motion/motion.conf
and confirm your target_dir /var/lib/motion (This is where Motion stores images and videos when it detects motion, this directory needs to be writable)
then ctrl + o and cntrl + x
Important step is to make that folder writeable!
sudo chmod 777 /var/lib/motion
and now it should work if you go to another computer and go to pi@{Raspberrypi_ip}:8081
Metonics
Sat Feb 23, 2019 11:18 am
Thanks but this did not seem to make any difference? Srill have exactly the same problem..
1. /etc/motion/motion.conf has:
[/b]
# This config file was generated by motion 4.2.1
# Documentation:  /usr/share/doc/motion/motion_guide.html
# This file contains only the basic configuration options to get a
# system working.  There are many more options available.  Please
# consult the documentation for the complete list of all options.
# System control configuration parameters
# Start in daemon (background) mode and release terminal.
daemon on
setup_mode off
# File to store the process ID.
; pid_file value
# File to write logs messages into.  If not defined stderr and syslog is used.
; log_file value
log_file /var/log/motion/motion.log
# Level of log messages [1..9] (EMG, ALR, CRT, ERR, WRN, NTC, INF, DBG, ALL).
log_level 6
# Target directory for pictures, snapshots and movies
# Video device (e.g. /dev/video0) to be used for capturing.
# Parameters to control video device.  See motion_guide.html
; vid_control_params value
# The full URL of the network camera stream.
; netcam_url value
# Name of mmal camera (e.g. vc.ril.camera for pi camera).
; mmalcam_name value
# Camera control parameters (see raspivid/raspistill tool documentation)
; mmalcam_control_params value
# Image Processing configuration parameters
# Image width in pixels.
width 640
# Image height in pixels.
height 480
framerate 100
stream_maxrate 100
# Text to be overlayed in the lower left corner of images
text_left CAMERA1
# Text to be overlayed in the lower right corner of images.
text_right %Y-%m-%d\n%T-%q
# Motion detection configuration parameters
# Always save pictures and movies even if there was no motion.
emulate_motion off
# Threshold for number of changed pixels that triggers motion.
threshold 1500
# Noise threshold for the motion detection.
; noise_level 32
# Despeckle the image using (E/e)rode or (D/d)ilate or (l)abel.
# Number of images that must contain motion to trigger an event.
# Gap in seconds of no motion detected that triggers the end of an event.
event_gap 60
# The number of pre-captured (buffered) pictures from before motion.
pre_capture 3
# Number of frames to capture after motion is no longer detected.
post_capture 0
# Script execution configuration parameters
# Command to be executed when an event ends.
# Command to be executed when a movie file is closed.
# Picture output configuration parameters
# Output pictures when motion is detected
picture_output off
# File name(without extension) for pictures relative to target directory
picture_filename %Y%m%d%H%M%S-%q
# Movie output configuration parameters
# Create movies of motion events.
movie_output off
# Maximum length of movie in seconds.
movie_max_time 60
# The encoding quality of the movie. (0=use bitrate. 1=worst quality, 100=best)
movie_quality 45
# Container/Codec to used for the movie. See motion_guide.html
movie_codec mkv
# File name(without extension) for movies relative to target directory
movie_filename %t-%v-%Y%m%d%H%M%S
# Webcontrol configuration parameters
# Port number used for the webcontrol.
# Restrict webcontrol connections to the localhost.
webcontrol_localhost on
# Type of configuration options to allow via the webcontrol.
webcontrol_parms 0
# Live stream configuration parameters
# The port number for the live stream.
stream_port 8081
# Restrict stream connections to the localhost.
# Camera config files - One for each camera.
; camera /etc/motion/camera1.conf
; camera /etc/motion/camera2.conf
; camera /etc/motion/camera3.conf
; camera /etc/motion/camera4.conf
# Directory to read '.conf' files for cameras.
; camera_dir /etc/motion/conf.d
2. /etc/default/motion has
3. have set
sudo chmod 777 /var/log/motion.log
but always get
pi@raspberrypi:~ $ ps -ef |grep motion
pi 5538 1214 0 22:16 pts/0 00:00:00 grep --color=auto motion
pi@raspberrypi:~ $ sudo service motion status
Loaded: loaded (/etc/init.d/motion)
Active: active (exited) since Thu 2019-02-21 19:29:44 AEDT; 2 days ago
Process: 470 ExecStart=/etc/init.d/motion start (code=exited, status=0/SUCCESS)
Feb 21 19:29:44 raspberrypi motion[470]: Starting motion detection daemon: m....
Feb 21 19:29:44 raspberrypi systemd[1]: Started LSB: Start Motion detection.
Feb 21 19:29:47 raspberrypi systemd[1]: Started LSB: Start Motion detection.
Feb 23 21:55:44 raspberrypi systemd[1]: Started LSB: Start Motion detection.
Hint: Some lines were ellipsized, use -l to show in full.
is there any way I can see where motion is failing to load/run from the diagnostics?
Souti
Fri Nov 01, 2019 12:04 pm
May be too late, but :
sudo -u motion motion
for me access rights error :
root@Akhenaton:/etc# sudo -u motion motion
[28735344:motion] [NTC] [ALL] conf_load: Processing thread 0 - config file /etc/motion/motion.conf
[28735344:motion] [ALR] [ALL] conf_cmdparse: Unknown config option "webcontrol_interface"
[28735344:motion] [NTC] [ALL] config_camera: Processing camera config file /etc/motion/camera1.conf
[28735344:motion] [NTC] [ALL] config_camera: Processing camera config file /etc/motion/camera2.conf
[28735344:motion] [NTC] [ALL] motion_startup: Motion 4.0 Started
[28735344:motion] [ERR] [ALL] myfopen: Error opening file /var/log/motion/motion.log with mode a: Permission denied
[28735344:motion] [EMG] [ALL] motion_startup: Exit motion, cannot create log file /var/log/motion/motion.log: Permission denied
Broadcast message from systemd-journald@Akhenaton (Fri 2019-11-01 12:53:41 CET):
motion[17491]: [28735344:motion] [EMG] [ALL] motion_startup: Exit motion, cannot create log file /var/log/motion/motion.log: Permission denied
root@Akhenaton:/etc# sudo chown -R motion:motion /var/log/motion/
[12171120:motion] [NTC] [ALL] conf_load: Processing thread 0 - config file /etc/motion/motion.conf
[12171120:motion] [ALR] [ALL] conf_cmdparse: Unknown config option "webcontrol_interface"
[12171120:motion] [NTC] [ALL] config_camera: Processing camera config file /etc/motion/camera1.conf
[12171120:motion] [NTC] [ALL] config_camera: Processing camera config file /etc/motion/camera2.conf
[12171120:motion] [NTC] [ALL] motion_startup: Motion 4.0 Started
[12171120:motion] [NTC] [ALL] motion_startup: Logging to file (/var/log/motion/motion.log)
root@Akhenaton:/etc# top
top - 13:04:16 up 1 day, 13:37, 4 users, load average: 1,42, 1,31, 1,22
Tâches: 304 total, 1 en cours, 249 en veille, 0 arrêté, 0 zombie
%Cpu(s): 2,4 ut, 0,7 sy, 0,0 ni, 96,9 id, 0,0 wa, 0,0 hi, 0,0 si, 0,0 st
KiB Mem : 3947544 total, 342108 libr, 1194896 util, 2410540 tamp/cache
KiB Éch: 4069372 total, 4027132 libr, 42240 util. 2246560 dispo Mem
PID UTIL. PR NI VIRT RES SHR S %CPU %MEM TEMPS+ COM.
17705 motion 20 0 161076 43256 18744 S 4,6 1,1 0:24.49 motion
6577 souti 20 0 623328 198996 8768 S 3,3 5,0 91:29.87 kodi.bin
3087 root 20 0 225088 18912 10704 S 1,0 0,5 15:44.64 domoticz
whatshisname
Mon Feb 10, 2020 3:15 am
Jumping in to confirm all of the above and to add what I've done in addition to what's been mentioned.
I'm running Arch on a Raspberry Pi 3.
I modified the motion.service file to run as "root" and not "motion".
I also modified the service file to start using a script that always works when I start it from the command line. But it fails every time as a service.
Scratching my head on this one along with everyone else.
Return to “Beginners”
