Muhsina
To check the status of relay using interrupt in raspberry pi
Tue Jul 10, 2018 6:50 am
Hi, I am working with a raspberry pi with a relay with the incandescent bulb, buzzer, and button via SSH. The code is in a way that when I press a key from the keyboard the bulb and buzzer should be ON and when I press button both should get OFF. But my button code is not working properly.
And also I want to check the status of the relay using the interrupt and whenever the light on it should be sent a message to the database. But I don't know with interrupts. Below is my code. Please help me. Thanks in advance
import RPi.GPIO as GPIO
import time
in1 = 25 #GPIO25 pin22
buzzer=24 #GPIO24 PIN18
led=8 #GPIO8 PIN24
button=23 #GPIO23 PIN 16
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO.setup(in1, GPIO.OUT)
GPIO.setup(buzzer,GPIO.OUT)
GPIO.setup(led,GPIO.OUT)
        #GPIO.setup(button,GPIO.IN,pull_up_down=GPIO.PUD_DOWN)
GPIO.setup(button, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.output(in1, False)
GPIO.output(buzzer,False)
GPIO.output(led,False)
try:
        GPIO.output(in1,False)
        while True:
# check from database whether it is effective or deffective .currently I have inputted from keyboard
                variable=raw_input()
                if variable=="a":
                        m=variable
                        for x in m:
                                GPIO.output(in1, True)
                                time.sleep(0.05)
                                time.sleep(0.05)
                        GPIO.output(buzzer,True)
                        GPIO.output(led,True)
                        if in1==True || buzzer==True:
                                print "messge to database:pending"
                #def my_callback(channel):
                #if GPIO.input(button) == True:
                GPIO.wait_for_edge(button, GPIO.FALLING)
                #if variable=="b":
                        #while 1:
                print "mesage to database:ack completed"
                        #else:
                                #pass
                #else:
                        #pass
except:
        GPIO.cleanup()
If there is any error in my code please help me to rectify that. Thanks
Z80 Refugee
Re: To check the status of relay using interrupt in raspberry pi
Tue Jul 10, 2018 6:53 am
Why have you posted this twice? viewtopic.php?f=91&t=217782
I won't read discussion split across two threads, please discontinue this one.
Military and Automotive Electronics Design Engineer (retired)
For the best service: make your thread title properly descriptive, and put all relevant details in the first post (including links - don't make us search)!
pcmanbob
Tue Jul 10, 2018 7:44 am
you have asked the same question 3 times
viewtopic.php?f=91&t=217733&p=1338666#p1338666
viewtopic.php?f=91&t=217782&p=1338925#p1338925
viewtopic.php?f=91&t=217786
and people have posted answers , how many time are you going to ask this ? you wont get a different answer just because you keep asking the question.
texy
Tue Jul 10, 2018 8:32 am
Yes please don't keep creating new threads on the same issue.
Texy
