how to check the status of relay pin using an interrupt.
Posted: Mon Jul 09, 2018 12:50 pm
by Muhsina
I am working with the 5v relay module with an incandescent bulb and raspberry pi3. I have done my code in a way that relay should work continuously if I press a key from keyboard and it should be off when another key is pressed. So now I want to check the status of the relay pin using the interrupt functions and then if the bulb is on it should send a message.
import RPi.GPIO as GPIO
import time
in1 = 16
buzzer=18
led=24
button=22
GPIO.setmode(GPIO.BOARD)
GPIO.setwarnings(False)
GPIO.setup(in1, GPIO.OUT)
GPIO.setup(buzzer,GPIO.OUT)
GPIO.setup(led,GPIO.OUT)
#GPIO.setup(button,GPIO.IN,pull_up_down=GPIO.PUD_DOWN)
GPIO.setup(button, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.output(in1, False)
GPIO.output(buzzer,False)
GPIO.output(led,False)
try:
GPIO.output(in1,False)
while True:
variable=raw_input()
if variable=="a":
m=variable
for x in m:
GPIO.output(in1, True)
time.sleep(0.05)
time.sleep(0.05)
GPIO.output(buzzer,True)
GPIO.output(led,True)
#def my_callback(channel):
#if GPIO.input(button) == True:
if variable=="b":
#while 1:
#else:
#pass
#else:
#pass
except:
GPIO.cleanup()
Please help me with the code. Thanks in advance.
Re: how to check the status of relay pin using an interrupt.
Posted: Mon Jul 09, 2018 2:48 pm
by pcmanbob
Hi.
There is no feed back on a relay pin ( I assume you mean the IN control pin ), if only function is to take a high or low input.
The only way to test if the relay is actually on is to use a spare relay contact ( if the relay has one ) and wire it as you would a normal switch to the pi gpio and then test this to see if the relay is active or not.
what ever you do not connect the relay contact that is connected to your bulb as any voltage over 3.3v with damage you pi gpio.
Posted: Tue Jul 10, 2018 8:33 am
by texy
Locking due to duplicate threads. Please post any further replies on this one :
viewtopic.php?f=91&p=1338925#p1338925
Texy
