DarkPlatinum
Contact: Website YouTube
OTP usb bit
Thu Jun 28, 2018 10:28 am
Hi! me again. As i was reading over booting a raspberry pi from a USB storage, it says there is a one time programmable bit. If i programmed this bit, does this mean i will only be able to boot this raspberry pi from USB? Does this mean i cant ever boot it again from a sd card again?
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3 1 * Raspberry Pi 3B + :mrgreen:
Check Out My Raspberry Site (Run on a Raspberry Pi 3B :) ): https://html.dynu.net
procount
Re: OTP usb bit
Thu Jun 28, 2018 10:33 am
No, it just adds another boot option for you.
EDIT: No, it will always try to boot from the SD card like it did before, but if one isn't fitted, it will look for a bootable FAT partition on any attached USB devices.
I believe the latest 3B+ models have this bit set in the factory anyway.
DarkPlatinum
Re: OTP usb bit
Thu Jun 28, 2018 10:40 am
Oh ok thanks! Are there any downsides from enabling this?
Re: OTP usb bit
Thu Jun 28, 2018 11:56 am
No. If it can't find a bootable SDCard it attempts to boot a USB device. So reverting to SDCards is easy.
This is a doctor free zone.
epoch1970
Re: OTP usb bit
Thu Jun 28, 2018 12:16 pm
No, it means if you have a bootable USB stick inserted at boot time, it will try to boot from that first.
Not true. It always tries the SD first.
If USB OTP is set, it will try USB (mass storage, network) next.
https://www.raspberrypi.org/documentati ... ootflow.md
procount
Re: OTP usb bit
Thu Jun 28, 2018 12:31 pm
Yes, sorry - my memory failed me. I have updated my post accordingly.
DarkPlatinum
Re: OTP usb bit
Thanks for your help!
DarkPlatinum
Re: OTP usb bit
Thu Jun 28, 2018 3:04 pm
Followed the Usb mass storage tutorial but im not getting the
vcgencmd otp_dump | grep 17:
17:3020000a
im getting
$ vcgencmd otp_dump | grep 17:
17:1020000a
also after cloning my rpi image iget a new boot.bak folder. the original boot folder is empty. i logged in as root and copy paste files from boot.bak to boot.
both config files in boot and boot.bak have arm freq of 1250, but im only getting 1200 mhz?
how do i get the correct code?
DarkPlatinum
Re: OTP usb bit
Thu Jun 28, 2018 3:35 pm
Looks like I have unmounted the boot partition on boot. Where is the boot partition supposed to be mounted?
My settings are: Mount at start up, defaults, noatime, mount point : / , identify as /dev/mmcblk0p1, file system fat.
DarkPlatinum
Re: OTP usb bit
Thu Jun 28, 2018 3:41 pm
On opening raspberry pi configuration application:
"The raspberry pi configuration application can only modify a standard configuration.
Your configuration appears to have been modified by other tools, and so this's application cannot be used on your system.
In order to use this application, you need to have the latest firmware installed, device tree enabled and the lightdm application installed"
DarkPlatinum
Re: OTP usb bit
Thu Jun 28, 2018 3:53 pm
Let me make a new thread
HawaiianPi
Re: OTP usb bit
Thu Jun 28, 2018 10:49 pm
Yikes! Don't do that from a modified or overclocked OS! :shock:
Start with a plain old stock, unmodified Raspbian Stretch imaged SD card. The Lite version will be fine for this.
Only edit the config.txt file to add the command to set the OPT bit with no other changes.
Boot that card in your system and check the bit status (might have to reboot).
