qtitnz
Bell System - School
Wed Jun 27, 2018 10:35 pm
Hi team,
I have RPi3 B+ with PiFace Digital 2 Interface
Alarm people at school has installed a 2 way wire to turn Amplifier on and off as well as stereo cable to plug to RPi, this amp controls alarms as well as bell system at school.
Wanting to achieve the following scenario:
- via relay, switch AMP on
- play wav file for 15 seconds to replace the current bell sound
- via relay, switch AMP off
- repeat during school brakes Monday to Friday (10am, 12pm, 3pm etc etc)
Can anyone maybe shed some light to achieve this ?
W. H. Heydt
Re: Bell System - School
Thu Jun 28, 2018 5:15 am
1. Write a shell script that does what you want. Be sure to either include setting the PATH variable inside the script...or give everything ablsolute paths.
2. Use cron (edit using "crontab -e") to set the times and days of the week you want the script to run. Again, point to the script using an absolute path.
Note: The reason for using absolute paths is because the normal environment variables, such as PATH, are not set. You are not running in a login shell.
pcmanbob
Thu Jun 28, 2018 5:20 am
The piface I believe already has relays on board so you simply need to connect the 2 wires to the relay terminals , one you connect to common the other to the normally open contact, then when you activate the relay the amp will be turned on.
you can play a wav file with aplay which is installed on raspbian by default, at the command line like this "aplay somewavefile.wav" if you wave file is 15 seconds long then then it will play for 15 seconds
see switch on above
you can run programs to a schedule using cron
so for example using crontabe -e
you would enter this line for the 10am playing.
0 10 * * 1-5 aplay /home/pi/name.wav
you can do the same to call the program that will activate the piface relay you simply need to have a delay in the program between turning relay on and then off again, you would call this a minute before the play command so the amp has time to power up.
this web site will help you with creating the correct cron line entries https://crontab-generator.org/
DirkS
Thu Jun 28, 2018 6:03 am
texy
Thu Jun 28, 2018 6:39 am
Duplicate of viewtopic.php?f=37&t=216919&p=1333899#p1333899
And locking, as such.
