Nownuri
UART pins(TX, RX) on Raspberry Pi Zero W
Wed Jun 27, 2018 9:34 am
I have two questions about the UART pins on RPi Zero W.
1. Are the pins protected against ESD? What would be the rating of the ESD protection, for instance, 15kV?
2. Do you always need to pull-up/down the TX pin? I observed that the RPi does not send data properly when the TX pin is not pulled up or down. I tested this using minicom.
Re: UART pins(TX, RX) on Raspberry Pi Zero W
Wed Jun 27, 2018 9:37 am
1. No
2. No
This is a doctor free zone.
bensimmo
Wed Jun 27, 2018 9:57 am
Have a look at this to see whihc UART it is using, it should be the miniUART.
At the bottom it links to the specs.
https://www.raspberrypi.org/documentati ... on/uart.md
klricks
Wed Jun 27, 2018 12:22 pm
No pull down is needed.
The voltage level of the other device must be 3V3 not 5V. If not 3V3 then a level shift circuit must be used on the RX pin.
There must be a ground wire connected between RPi and device.
Arjan
Wed Jun 27, 2018 12:31 pm
In general, all the GPIO pins on the external header are directly connected to the SoC. At any time we should be careful in direct controlling of external devices.
http://www.raspberrypi-dmx.org/
Open Source DMX/RDM/MIDI/OSC/Art-Net/sACN solutions
