tarangdodia
Can shorting all ground pins of Rpi?
Fri Jun 22, 2018 12:41 pm
What will happen if I short all the ground pins of raspberry pi 3?
Does that effect in working of GPIO's?
texy
Re: Can shorting all ground pins of Rpi?
Fri Jun 22, 2018 2:13 pm
H and welcome to the forum.
All the ground pins of the GPIO port are already shorted - they are effectively the same signal. So you will do no damage.
Texy
alphanumeric
Fri Jun 22, 2018 8:08 pm
If you have a Hat or Phat that is not plugged into a PI, you may find that all of the grounds are not connected together. They rely on the fact that they are common on the Pi. Plug it into the Pi and they are then all connected together. This has caught me out once, had me scratching my head for a minute anyway.
I had a powerboost breakout board mounted on a Proto Zero pHat. I had a switch wired to the enable pin to ground it and turn the up converter off. I tested it while it was not plugged into the Pi and it didn't work. Got my ohm meter out and found the ground pin I used wasn't common with the ground I used for the powerboost. Plugged it into the Pi's GPIO and it worked as I had intended.
