basvs
Run (Camera) Script on bootup
Sat Apr 28, 2018 5:00 pm
Hi all,
I'm trying to build an interactive system which sends video to a browser accessible to all inhabitants in a home-environment. Using the Raspberry Pi Zero (headless), I followed this tutorial (https://desertbot.io/blog/how-to-stream-the-picamera) and it all works fine now.
However, since I'll be placing my system in some else's house for a week long deployment test, I'm trying to get the raspberry start sending video automatically once booted up. I pretty sure this must be possible, however I wasted the whole afternoon with failed attempts, so some help would be welcome :)
Basically, the Raspberry needs to execute the following commands automatically after WiFi has been initiated and I'll be set (hopefully):
cd /home/pi/projects/mjpg-streamer/mjpg-streamer-experimental/
./mjpg_streamer -o "output_http.so -w ./www" -i "input_raspicam.so"
Anyone knows how to get this done?
All the best,
Bas
pcmanbob
Re: Run (Camera) Script on bootup
Sun Apr 29, 2018 1:11 pm
Hi.
One way to do this would be to use cron and the command @reboot
Now as you want to be sure your pi is connected to wifi I would add a delay to give the pi a change to make the wifi connection.
so at the command line
crontab -e
if you have not used cron before just accept the default editor which is nano.
one the file opens scroll to the bottom of the file and add this line
@reboot sleep 60 && /home/pi/projects/mjpg-streamer/mjpg-streamer-experimental/mjpg_streamer -o "output_http.so -w ./www" -i "input_raspicam.so"
you should also make sure there is a blank line after this line.
then do Ctrl & o to write the file
and Ctrl & x to exit
if all is well you should get a message installing new cron.
now when you boot or reboot your pi will wait 60 seconds and then start mjpg with your options.
basvs
Mon Apr 30, 2018 5:59 pm
Hi!,
thanks, it seems like this is what I'm looking for, however, it does not work yet :(
I find it super weird, because whenever I'm executing the following lines from my Mac terminal to Rasperry Pi, it works;
export LD_LIBRARY_PATH=/home/pi/projects/mjpg-streamer/mjpg-streamer-experimental/
but as soon as I put the two last lines together (see below), I get a 404 error on the webserver:
my crontab now looks like this, but whatever I change, it does not even seem to start the server...
@reboot sleep 60 && export LD_LIBRARY_PATH=/home/pi/projects/mjpg-streamer/mjpg-streamer-experimental/
Any idea what this could cause? Thanks in advance :)
Best,
Bas
KLL
Mon Apr 30, 2018 6:48 pm
possibly need
+ 2 more " && "
and
- 2 less " enter "
so try
@reboot sleep 60 && export LD_LIBRARY_PATH=/home/pi/projects/mjpg-streamer/mjpg-streamer-experimental/ && cd /home/pi/projects/mjpg-streamer/mjpg-streamer-experimental && mjpg_streamer -o "output_http.so -w ./www" -i "input_raspicam.so"
but how about style? try a script from there:
nano mystart
#!/bin/sh
sleep 60
chmod +x mystart
crontab -e
@reboot /home/pi/projects/mjpg-streamer/mjpg-streamer-experimental/mystart
( not tested )
basvs
Tue May 01, 2018 6:50 pm
You're the boss! This works.
Thanks a lot! :D
