mini usb leds
Posted: Fri Jan 05, 2018 10:09 am
by DPaul
Before i do anything stupid:
I have a number of USB mini flex lights, the kind that you stick into your laptop for lighting the keyboard.
Like so:
https://www.amazon.com/Flexible-USB-Lig ... B0191S9I4K
For my project i plan to use a Pi zero W, where i am in short supply of USB ports.
But i need a lamp illuminating the keypad on the device i am making (attempting to make)
Question: can i take one of these Led lights, cut the usb connector, and connect it to a GPIO pin / 5 volts / resistor combo,
just like any other led ? Or is there a more clever alternative?
An added benefit for me (as opposed of having a permanent USB connected light) would be that i can write a script
that turns the lamp on and off, when the user needs to do something or sit idle.
thx,
Paul
Re: mini usb leds
Posted: Fri Jan 05, 2018 11:04 am
by pcmanbob
You could cut the end off but you don't know what your will find inside may not be easy to connect to external supply, but if your project is in some sort of case why not mount a USB socket in the case so you can just plug your lamp in to it.
Then you can power the socket via a transistor from the 5v pin on the gpio which will allow you to turn it on and off using a gpio pin controlling the transistor.
Re: mini usb leds
Posted: Sat Jan 06, 2018 11:03 am
by DPaul
Thx, good idea, i did not know those things could be purchased as sockets.
They seem to have 4 contacts. Now i just have to find a wiring scheme :)
Paul
Re: mini usb leds
Posted: Sat Jan 06, 2018 11:13 am
by pcmanbob
The socket is classed as the male in this diagram.
Re: mini usb leds
Posted: Sun Jan 07, 2018 7:47 am
by DPaul
Wow, thanks.
Using all of my three-month experience with these matters,
am i correct in guessing:
a) This is a front view
b) 99% of those usb sockets in the world have the same layout
c) I leave the data pins alone
d) if i choose to control on/off programmatically,
i can do that like any other little led lamp via a 330 ohm resistor to ground.
e) Vcc being the 5 volt pin.
Paul
Re: mini usb leds
Posted: Sun Jan 07, 2018 8:10 am
by rpdom
Yes.
No. 100% of USB sockets have the same layout. It is a standard.
Yes.
No. They will already have a resistor built in to the unit. They will require 5 Volts at around 240mA to work properly. To control that programmatically you would need to use a transistor to switch the 5V from a 3.3V GPIO pin.
Yes.
I'm now curious to see what is inside those LED units, so I've ordered a few to play with. I'll find out in a few weeks :-)
Re: mini usb leds
Posted: Sun Jan 07, 2018 8:23 am
by DPaul
OK, thanks.
Got my Pi zero W in yesterday, so i know what to do in the next few days :D
Paul
Re: mini usb leds
Posted: Sun Jan 07, 2018 12:31 pm
by pcmanbob
All you need is a 470 ohm resistor and a 2n2222 transistor wired to the gpio and USB socket like this.
you can use any of the gpio pins to control this with a simple python program.
Re: mini usb leds
Posted: Sun Jan 07, 2018 3:39 pm
by DPaul
Could a NPN BC548 transistor do ?
Got a bunch of them
thx,
paul
Re: mini usb leds
Posted: Sun Jan 07, 2018 3:47 pm
by pcmanbob
Got a bunch of them
thx,
paul
BC548 is only rated for 100mA
2n2222 is rated at 800mA
your lights 240-260mA so no BC548 wont do.
Re: mini usb leds
Posted: Sun Jan 07, 2018 4:41 pm
by DPaul
Another 90 eurocent investment ! :shock:
Paul
Re: mini usb leds
Posted: Tue Jan 09, 2018 8:36 am
by DPaul
I have found an inordinate amount of usb sockets on the net.
Some even are "power socket only". No data !
If you want one that is also "easy to install in a small case", it's rare.
(Not if you want to pay lots of money (relatively)). It's actually a lot
cheaper to buy a 5 slot usb hub.
Because, if i solder the "USB type A" to the PCB,
it becomes more difficult to plug the LCD lamp, and get it back out again.
It is supposed to be user friendly.
Maybe dismantling a cheaper usb hub could be a solution.
You get 4 or 5 sockets in one go....
Paul
Re: mini usb leds
Posted: Tue Jan 09, 2018 10:32 am
by pcmanbob
Don't know were in the world you are but you can get them from china for 99P
https://www.ebay.co.uk/itm/Magic-USB-5p ... SwdGFYrVCn
https://www.ebay.co.uk/itm/USB-2-0-A-Ma ... SwRH5XKbUN
the first one is actually the same both ends so you could cut it in half and end up with 2 sockets !
Re: mini usb leds
Posted: Tue Jan 09, 2018 10:49 am
by Mortimer
It looks like a solution to use a USB socket is being followed.
In case there was any doubt however, the other thing to be careful of with USB powered devices, is that often the USB plug body is where electronics is hidden. It is unlikely in this case, although there might be a resistor or constant current circuit inside the plug, and by cutting this off, something may have been lost that protects the LEDs.
Re: mini usb leds
Posted: Tue Jan 09, 2018 11:18 am
by DPaul
Yes , i have seen the ones on the ebay UK site, but shipping is from Hong-Kong.
They will take a month or more to get here. (here = where i can almost see Albion)
Who has that kind of patience ? :?
Dismantling has ben done on youtube of course :
https://www.youtube.com/watch?v=4RfMiyjQ12s
fun!
Paul
Re: mini usb leds
Posted: Fri Jan 12, 2018 10:40 am
by DPaul
I ended up buying these. I ordered 5 for the price of 1 i found locally.
When i cut the cord, i hope to find the right wires ;)
Paul
Re: mini usb leds
Posted: Fri Feb 09, 2018 8:33 am
by DPaul
At long last they have arrived from China!
Seem to bee very OK.
I cut off one end and stripped the wires, to find the 4 colors i was expecting.
Next stop, add some usb ports to the pie zero !
Paul
Re: mini usb leds
Posted: Fri Feb 09, 2018 4:57 pm
by Mortimer
I would still buzz them out, it is not unknown for wires to be swapped in low cost Chinese sourced components.
