secreus
(SOLVED) Lost storage from formatting Raspbian microSD
Tue Dec 26, 2017 9:46 pm
So a while back, I got to work on my Raspberry Pi VPN project and had everything set up. I remembered making some options correct, but we've changed our internet plan since then to a static IP address. I looked for a way to delete/restart OpenVPN/Raspbian but couldn't find any; so I formatted the entire 32 gig microSD in Windows. Now, there's two drives when I put in my microSD; one is the SD slot with 41.5 megabytes open, and the other is a USB drive with 14.7 gigabytes open. Is there any way to recover the lost storage and get the card back to display as one single drive?
Re: Lost storage from formatting Raspbian microSD
Wed Dec 27, 2017 6:05 am
Windows natively will only read the first partition if FAT or NTFS formatted.
SD Card Formatter may get the SD Card back to one partition:
https://www.sdcard.org/downloads/formatter_4/
Retired disgracefully.....
beta-tester
Wed Dec 27, 2017 8:20 am
don't care about the second partition that windows can not handle - do not try to repair or format that partition, when windows is asking you.
the second partition is formated with a file system (ext4) that windows don't know, but it is the root file system for linux and the linux world knows how to handle that ;)
simply follow the installation guide to prepare & install a new sd card...
https://www.raspberrypi.org/downloads/raspbian/
RPi Model B (rev1, 256MB) & B (rev2, 512MB) & B+, RPi2B, RPi3B, RPi3B+, RPiZeroW, ...
