pnaven03
How to complete power of raspberry pi 3 board using commands
Fri Sep 01, 2017 6:39 am
Hi Team,
We are using raspberry pi 3 and kernel version Linux raspberrypi 4.4.11-v7+ #888 SMP Mon May 23 20:10:33 BST 2016 armv7l GNU/Linux, am using turning off raspberry pi board using command "sudo shutdown -h now" using this command not complete turn off , lcd screen showing white color , still power led ON state , how to complete turn off with lcd using command line without remove power adapter, is is possible or not ,
please any one help me on this issue.
Regards,
Nv
B.Goode
Re: How to complete power of raspberry pi 3 board using commands
Fri Sep 01, 2017 7:07 am
Not.
KLL
Fri Sep 01, 2017 7:37 am
if you could use the USB port power for LCD? that would be shut down / power up by the RPI3 board,
if you use the 5Vpin NOT.
pnaven03
Fri Sep 01, 2017 11:46 am
Thanks for the reply,
No we are not using usb power for LCD.
Any methods to complete turn off raspberry pi 3 using commands.
please any one help me on this.
BMS Doug
Fri Sep 01, 2017 11:51 am
You will need additional external hardware to achieve this.
Doug.
pnaven03
Fri Sep 01, 2017 12:47 pm
BMS Doug,
please can you share me the any links for solution.
BMS Doug
Fri Sep 01, 2017 2:22 pm
Pi supply power switch
How does it work?
Once you have finished using your Raspberry Pi, you just shutdown using the sudo halt command, and then a couple of minutes after the full and safe shutdown the Pi Supply Switch cuts the power to the computer. From this point, once again, all you would need to do to restore power to the Pi is touch the on button.
There is also a hard power off button for use in emergencies which immediately cuts the power to your Raspberry Pi. Remember to only use this button when absolutely necessary (e.g. Pi has been frozen for a long time) as it risks corruption of the files on your SD card if done at the wrong moment.
What makes the Pi Supply Switch superior to other makeshift solutions available is that it allows you to restart the Raspberry Pi using the sudo reboot command without the power turning itself off. Perfect!
Doug.
Fri Sep 01, 2017 3:47 pm
Or http://www.uugear.com/product/wittypi2/ which includes a RTC and can start/stop your RPi on a timer schedule.
This is a doctor free zone.
