Jayce
How to use "go get" command in terminal?
Sun Jul 16, 2017 10:05 am
As part of the package installation instructions, this line must be typed in the terminal:
go get -u -v -tags all github.com/blevesearch/bleve/..
However, the terminal states that the go command is unknown. So how to use go get command?
Re: How to use "go get" command in terminal?
Sun Jul 16, 2017 10:21 am
Which package and which instructions? We are not mind readers.
The use of "go" suggests that you might need the "go" language installed. If the instructions don't tell you to do that I'm not sure how good the rest of them are.
DirkS
Sun Jul 16, 2017 10:25 am
You will need Go (golang) installed for that.
http://www.blevesearch.com/
https://golang.org/
Jayce
Sun Jul 16, 2017 12:56 pm
rpdom wrote:Which package and which instructions? We are not mind readers.
https://github.com/akhenakh/gozim This is what i've been trying to install. I was just following the instructions.
DirkS wrote:You will need Go (golang) installed for that.
https://golang.org/
Currently downloading Golang. I'll tell you the results once it is done.
buja
Sun Jul 16, 2017 1:15 pm
I would suggest to install Go the usual (Raspbian) way:
sudo apt-get install golang
