Berryboot file sistem backup
Posted: Sat May 06, 2017 3:01 pm
by Vairetz
Hi guys I have a problem with berryboot, I'd like to make a backup of my Raspbian OS with all data and programs but when I try to do it in the berryboot menù it tells me that I need to insert a usb driver even if it is already connected. I didn't get which is the problem
Re: Berryboot file sistem backup
Posted: Sun May 07, 2017 5:20 am
by KLL
Vairetz wrote:a backup of my Raspbian OS
berryboot menù
as far as i remember when i last time play berryboot
the backup and restore of OS's to USB stick is its best ( and fastest ) feature.
try a other / empty USB stick.
Posted: Sun May 07, 2017 10:02 pm
by Vairetz
I've tried different USB stick but the problem is the same.. I didn't get why it tells me USB drive doesn't detected
Posted: Mon May 08, 2017 2:37 am
by KLL
Vairetz wrote:it tells me USB drive doesn't detected
-a- did you try to boot with connected USB stick or "hot plug" ?
-b- in the menu you not find the usb drive OR it "tell you" some error msg?
update:
i just loaded a berryboot raspbian into berryboot
some small changes,
reboot
and put in a usb stick,
berryboot menu BACKUP
original + mod
to sda1
after 9 min reboot to raspbian and check usb stick:
pi@RPI0:~ $ df
Filesystem     1K-blocks    Used Available Use% Mounted on
/dev/sda1       15623040 3176768  12446272  21% /media/pi/APACER16GB
pi@RPI0:~ $ ls -la /media/pi/APACER16GB/
total 3176772
-rw-r--r--  1 pi   pi   3252965376 Jan  1  1980 MODIFIED-Debian_Jessie_Raspbian_2016.11.img192
sadly after update / upgrade RASPBIAN system ( to 4.9.24-v7 ?)
it not booted any more ( tested 2 times )
Posted: Mon May 08, 2017 6:26 am
by hommar
KLL wrote:to sda1
may be usb stick is w/o partition?
i.e. system has /dev/sda only.
Posted: Tue May 09, 2017 9:08 pm
by Vairetz
When I go to the berry boot menù option to backup my OS it tells me: "no USB stick detected". USB is without partition and it's formatted in FAT32
Posted: Tue May 09, 2017 9:36 pm
by hommar
Vairetz wrote:USB is without partition and it's formatted in FAT32
need MBR + single partition + format FAT32 this partition
PS better use SDFormatter for format USB stick
Posted: Wed May 10, 2017 2:22 am
by KLL
Vairetz wrote:When I go to the berry boot menù option to backup my OS it tells me: "no USB stick detected".
when you have that ( any ) usb stick in the RPI ( while you run RASPBIAN )
and you try command
df
raspbian see the usb stick?, it calls it ? sda1 ?
i know its not same OS like berryboot but its a good start, if raspbian see a stick you remember the drive name ?sda..?
and reboot to berryboot menu. it should also see it ( unless it is a 64GB.. or other special drive where
berryboot could have only older driver / be unable to mount )
if you not see any usb stick ( in raspbian or berryboot ) possibly USB port bad?
you see a blinking LED in the usb stick when you connect it?
Posted: Fri May 12, 2017 1:02 pm
by Vairetz
and you try command
df
In Raspbian I can use the USB stick and it's called sda1 but when I reboot the sistem I have the same problem, I try to connect the usb to another usb port but it's the same
