gets.chomp
How do you update your Raspbian ?
Wed Apr 26, 2017 12:53 pm
Hi everyone !
When I was checking the documentation of the Raspberry Pi, I found that they recommend updating the kernel using "rpi-update".
However on Stack Exchange I also read that doing "sudo apt-get update" followed by "sudo apt-get upgrade" also updated the whole Raspbian installation, kernel and everything ?
After using this second method I indeed saw my Splash Screen indicating a more recent version at boot.
So what's the best and the difference between "rpi-update" and "sudo apt-get update" followed by "sudo apt-get upgrade" ? I also saw "sudo apt-get dist-upgrade" in the documentation but don't understand the difference with "upgrade" :/.
Thanks !
RaTTuS
Contact: Twitter YouTube
Re: How do you update your Raspbian ?
Wed Apr 26, 2017 12:57 pm
sudo apt-get update && sudo apt-get dist-upgrade
only do rpi-update if you have been told to in reference to a particular problem
Covfefe
Wed Apr 26, 2017 1:01 pm
gets.chomp wrote:Hi everyone !
Thanks !
Nowadays rpi-update installs a Testing Kernel / Firmware and has not been recommended, unless under advisement, since Raspbian Jessie WS released in Sept 2015.
To update Raspbian Jessie with Pixel weekly, which includes any Kernel / Firmware, I undertake:
sudo apt-get update
https://linux.die.net/man/8/apt
Retired disgracefully.....
gets.chomp
Wed Apr 26, 2017 1:04 pm
Thanks guys !
What's the difference between "sudo apt-get upgrade" and "sudo apt-get dist-upgrade" though ?
ShiftPlusOne
Wed Apr 26, 2017 1:21 pm
gets.chomp wrote: When I was checking the documentation of the Raspberry Pi, I found that they recommend updating the kernel using "rpi-update".
Where is that?
Wed Apr 26, 2017 1:30 pm
gets.chomp wrote:Thanks guys !
https://linux.die.net/man/8/apt-get
gets.chomp
Wed Apr 26, 2017 2:15 pm
Thanks.
Ok now I get it, cool site as well. However if I "mistakenly" used "upgrade" instead of "dist-upgrade" to make the first update of my Pi after a fresh install of Raspbian, is that a liability that could cause problems down the line ? Thanks !
Where is that?
https://www.raspberrypi.org/documentati ... pdating.md
Wed Apr 26, 2017 2:19 pm
You can also manually update the Rasperry Pi stock kernel, but this is not recommended.
So it is NOT recommended........
Wed Apr 26, 2017 2:45 pm
That page should really have a link back to the normal update procedure.
I'll fix that.
gets.chomp
Wed Apr 26, 2017 2:49 pm
jamesh wrote:That page should really have a link back to the normal update procedure.
I'll fix that.
Thanks for taking feedback into account ! indeed for noobs it could clarify.
W. H. Heydt
Wed Apr 26, 2017 2:52 pm
These days, I usually follow the update/(dist-)upgrade with "sudo apt-get clean" to remove any lingering, but unneded files.
gets.chomp
Wed Apr 26, 2017 3:07 pm
If I "mistakenly" used "upgrade" instead of "dist-upgrade" to make the first update of my Pi after a fresh install of Raspbian, is that a liability that could cause problems down the line ? Thanks !
Wed Apr 26, 2017 3:51 pm
gets.chomp wrote:If I "mistakenly" used "upgrade" instead of "dist-upgrade" to make the first update of my Pi after a fresh install of Raspbian, is that a liability that could cause problems down the line ? Thanks !
Not at all....
Wed Apr 26, 2017 4:20 pm
I'll fix that.
Draft version of change.
https://github.com/raspberrypi/document ... pdating.md
PeterO
Wed Apr 26, 2017 4:27 pm
I would have opened with something that said there is no need to manually update the kernel as it happens automatically with the regular raspbian updates.
PeterO
gets.chomp
Wed Apr 26, 2017 6:17 pm
Sorry guys but I come with a new question about something that puzzles me a bit.
Earlier today I did a sudo apt-get upgrade and it did download and install stuff.
Tonight, I ran sudo apt-get dist-upgrade following our previous discussion here, and it's also downloading and installing stuff, it seems even more than before.
Is that normal ?
Wed Apr 26, 2017 6:29 pm
gets.chomp wrote:Sorry guys but I come with a new question about something that puzzles me a bit.
Is that normal ?
Yes definitely as per: https://linux.die.net/man/8/apt-get
Wed Apr 26, 2017 7:10 pm
I'd add some warning about third-party kernels, like some of the special LCD drivers.
The Monkey
Wed Apr 26, 2017 7:38 pm
sudo apt-get update also sudo apt-get upgrade OR sudo apt-get update && sudo apt-get upgrade.
Wed Apr 26, 2017 7:56 pm
The Monkey wrote:sudo apt-get update also sudo apt-get upgrade OR sudo apt-get update && sudo apt-get upgrade.
What is this in response to ? and who is it aimed at ? and the options have been discussed !!
Wed Apr 26, 2017 8:25 pm
PeterO wrote:I would have opened with something that said there is no need to manually update the kernel as it happens automatically with the regular raspbian updates.
PeterO
Good idea. Will put that in tomorrow. If I remember. Or you can send a PR based on the draft, I think.....
Wed Apr 26, 2017 9:42 pm
PeterO
I thought you needed both raspberrypi-kernel and raspberrypi-bootloader packages to revert from an rpi-update.
This is a doctor free zone.
Rascas
Wed Apr 26, 2017 10:38 pm
W. H. Heydt wrote:These days, I usually follow the update/(dist-)upgrade with "sudo apt-get clean" to remove any lingering, but unneded files.
apt-get clean cleans all the apt packages cache, all the packages that were download since the OS installation. This is only normally done if there is the need to free up some space, because in production systems it might be usefull to get old packages versions available, mainly if a new one installed doesnt work well with some software, specially if the internet connection gets broken. Just my 2 cents ;)
Thu Apr 27, 2017 5:34 am
That's what backups are for.
If running Debian the old versions will be available on the servers for year. Raspbian doesn't keep old versions as they can't justify the extra space that keeping all the old packages would need.
For 99.99% of users that package cache is just taking up space which could be needed for something else.
bensimmo
Thu Apr 27, 2017 6:22 am
Here is the official one I know of
It should be noted that I now just use apt instead of apt-get because it's slightly easier to follow what's happening on screen. (Much nicer for beginners and teachers as you see progress)
Also it's used in places around RaspberryPi documentation iirc, perhaps have these link to the update procedure now?
However it doesn't matter as long as it's consistent.
As a side, you should mention 'autoclean' as it will be mentioned to the user while updating at some point.
Maybe also an ipv6 error note for when ipv6 connections are blocked at some point and it borks the update procedure as it doesn't rollover to another IP address. I know is its regular under our school setup (probably the nanny) and i know others that have seen it.
(Just ctrl-c and repeat until they all come from good old ipv4)
