BenV
Lidar Lite V3 - Raspberry Pi - Python
Fri Mar 31, 2017 5:32 am
Hi guys,
Pretty new to this! Is there any library I can use to get distance and velocity from the Lidar Lite v3? Im on a Pi 3 and using Python.
Thanks,
B
wh7qq
Re: Lidar Lite V3 - Raspberry Pi - Python
Sat Apr 01, 2017 12:26 am
If you google "lidar lite raspberry pi" you will find a lot of references to doing just that.
Hove
Sat Apr 01, 2017 7:30 am
Here's mine:
#  Garmin LIDAR-Lite V3 range finder
class GLL:
    i2c = None
    __GLL_ACQ_COMMAND       = 0x00
    __GLL_STATUS            = 0x01
    __GLL_SIG_COUNT_VAL     = 0x02
    __GLL_ACQ_CONFIG_REG    = 0x04
    __GLL_VELOCITY          = 0x09
    __GLL_PEAK_CORR         = 0x0C
    __GLL_NOISE_PEAK        = 0x0D
    __GLL_SIGNAL_STRENGTH   = 0x0E
    __GLL_FULL_DELAY_HIGH   = 0x0F
    __GLL_FULL_DELAY_LOW    = 0x10
    __GLL_OUTER_LOOP_COUNT  = 0x11
    __GLL_REF_COUNT_VAL     = 0x12
    __GLL_LAST_DELAY_HIGH   = 0x14
    __GLL_LAST_DELAY_LOW    = 0x15
    __GLL_UNIT_ID_HIGH      = 0x16
    __GLL_UNIT_ID_LOW       = 0x17
    __GLL_I2C_ID_HIGHT      = 0x18
    __GLL_I2C_ID_LOW        = 0x19
    __GLL_I2C_SEC_ADDR      = 0x1A
    __GLL_THRESHOLD_BYPASS  = 0x1C
    __GLL_I2C_CONFIG        = 0x1E
    __GLL_COMMAND           = 0x40
    __GLL_MEASURE_DELAY     = 0x45
    __GLL_PEAK_BCK          = 0x4C
    __GLL_CORR_DATA         = 0x52
    __GLL_CORR_DATA_SIGN    = 0x53
    __GLL_ACQ_SETTINGS      = 0x5D
    __GLL_POWER_CONTROL     = 0x65
    def __init__(self, address=0x62, rate=10):
        self.i2c = I2C(address)
        self.rate = rate
        # Set to continuous sampling after initial read.
        self.i2c.write8(self.__GLL_OUTER_LOOP_COUNT, 0xFF)
        # Set the sampling frequency as 2000 / Hz:
        # 10Hz = 0xc8
        # 20Hz = 0x64
        # 100Hz = 0x14
        self.i2c.write8(self.__GLL_MEASURE_DELAY, int(2000 / rate))
        # Include receiver bias correction 0x04
        self.i2c.write8(self.__GLL_ACQ_COMMAND, 0x04)
        # Acquisition config register:
        # 0x01 Data ready interrupt
        # 0x20 Take sampling rate from MEASURE_DELAY
        self.i2c.write8(self.__GLL_ACQ_CONFIG_REG, 0x21)
    def read(self):
        # Distance is in cm
        # Velocity is in cm between consecutive reads; sampling rate converts these to a velocity
        # Reading the list from 0x8F seems to get the previous reading, probably cached for the sake
        # of calculating the velocity next time round.
        gll_bytes = self.i2c.readList(0x80 | self.__GLL_LAST_DELAY_HIGH, 2)
        dist1 = gll_bytes[0]
        dist2 = gll_bytes[1]
        distance = ((dist1 << 8) + dist2) / 100
        dist1 = self.i2c.readU8(self.__GLL_FULL_DELAY_HIGH)
        dist2 = self.i2c.readU8(self.__GLL_FULL_DELAY_LOW)
        velocity = -self.i2c.readS8(self.__GLL_VELOCITY) * self.rate / 100
        return distance, velocity
www.pistuffing.co.uk - Raspberry Pi and other stuffing!
BenV
Sun Apr 02, 2017 6:28 am
Thanks for sharing! Will definitely try that and get back to you.
jasonlayton2121
Wed Apr 19, 2017 4:07 pm
Why didn't you use the smbus on your python code for the lidar v3 range finder?
Hove
Thu Apr 20, 2017 5:18 am
I do use the smbus in my code, but because I have 3 sensors using it, it's broken out in a different class shared by all three. Have a look on GitHub at Quadcopter.py https://github.com/PiStuffing/Quadcopte ... dcopter.py. The code up to line 145 is the smbus class which the LiDAR code calls.
KrookdFinger
Sat May 13, 2017 11:53 pm
Hey Guys,
I had the Lidar Lite V3 working just fine... just upgraded firmware and now I am not getting any distance information back.
i2cdetect shows connected at 0x62. No errors in my software... distances just not coming in now.
Firmware version 4.9.27-v7+
Any ideas what to do?
Thanks.
Hove
Sun May 14, 2017 5:05 am
KrookdFinger wrote:Hey Guys,
Thanks.
I've never upgraded my firmware, didn't know you could, so sorry, I don't know how to help here.
KrookdFinger
Mon May 15, 2017 2:39 pm
Sorry. Just read my post. I never said what I upgraded. I upgraded my raspberry pi to 4.9.27-v27. Some library must be different. I went to the first build of jessy with pixel and all works fine. Any idea were I should look to check i2c settings between versions?
Hove
Mon May 15, 2017 3:28 pm
Any official version of Jessie should work fine - just get the latest version: https://www.raspberrypi.org/downloads/raspbian/
I use the lite version - I don't want PIXEL and all the other GUI stuff taking up CPU power, but that will have no effect on the I2C.
The only changes I make to I2C are enable I2C in raspi-config and then add this line to /boot/config.txt
dtparam=i2c_arm_baudrate=400000
The last bit is only necessary as I need this speed for the IMU also running over I2C.
Where did you get your version of Raspian PIXEL from?
KrookdFinger
Mon May 15, 2017 8:07 pm
I did a rpi-update and i2c for lidar-lite v3 stopped working.
i2cDetect shows lidar as connected... but it will no longer return distances... they come back as zero.
I reverted back to raspbian-2017-01-10 from http://downloads.raspberrypi.org/raspbian/images/
and everything works again.
I'm just wondering what library may be causing the break.
Thank you,
Robert
Hove
Tue May 16, 2017 6:16 am
Hi Robert,
Sorry, can't help; I think mine are running on the March Jessie lite, but I know they've run on the January & February versions too.I'd be very surprised that I2C got broken in the April version. Do you have any other I2C devices that are still working fine?
I have found the LiDAR Lite is very sensitive to cable length. It never works with the full length cable they supply. A couple of centimetres shorter and all's fine. The symptoms I saw was it was messing up the I2C bus - I kept getting I2C errors trying to read the IMU; unplug the LiDAR and IMU worked. Shorten the LiDAR cable and IMU worked.
Andy
zurmikopa
Fri May 19, 2017 8:31 pm
I have the same issue as KrookdFinger. It just returns 0s when using the pi.
I set up the pi recently, so I haven't tried reverting to a previous version to see if that helps.
I have, however, tried the lidar lite on an arduino with i2c, which works fine, so I don't think it's a cable length issue.
Hove
Sat May 20, 2017 5:28 am
Do you have anything else on the I2C bus other than Garmin? My Garmin works perfectly, but iff its plugged in, my MPU-9250 struggles.
Have you set the I2C baudrate to 400kbps? Have you tried the Python code I posted earlier - this works for me.
zurmikopa
Sun May 28, 2017 4:58 am
Stupid question, in your (Hove's) code, I see
But I don't see I2C defined anywhere.
What would I need to import to get that?
Hove
Sun May 28, 2017 6:06 am
zurmikopa wrote:Stupid question, in your (Hove's) code, I see
I2C is just a thin wrapper around smbus which is imported at the top. Take a look at github.com/PiStuffing/Quadcopter/Quadcopter.py, and look for "class I2C:" and "class GLL:"
zurmikopa
Sun May 28, 2017 6:57 am
Ah, thanks.
Tried your code.
Unfortunately it is still always returning (0,0) when I call read.
I am also getting zeros with this library someone made for lidar lite:
https://github.com/Sanderi44/Lidar-Lite
I added dtparam=i2c_arm_baudrate=400000 to my /boot/config.txt
i2cdetect seems to indicate it's there.
Nothing else is on the I2C bus.
My version of pixel was downloaded through noobs, followed by an update/upgrade.
Despite my lack of success, I really appreciate the responses, thanks.
Hove
Sun May 28, 2017 7:14 am
How is your LiDAR attached to the Raspberry Pi? I haven't seen problems matching exactly what you see, but I have seen getting rubbish values from it. The main problem I've had is the wires they give are too long - if they are 1/2 or less in length, it works a lot better. Also, the LiDAR spec says to use a 680uF capacitor across 5v and ground - if I use that, I only get rubbish out.
zurmikopa
Sun May 28, 2017 7:31 am
I do have the 680uF capacitor across 5v and ground, what might you suggest in place of it, just nothing?
The rest of the wiring is blue -> pin 3 , green -> pin 5, yellow & orange unconnected.
I use the same wiring setup with an Arduino and it works. (Except the last bit is male instead of female on the Arduino, but same wire length.)
I'll see if I can get the wires shorter just to check though.
Hove
Sun May 28, 2017 7:38 am
I just removed the capacitor completely and shorten the wires. To me it seems about 10cm cables is about the point things start failing even with the capacitor removed.
KrookdFinger
Tue May 30, 2017 5:20 pm
Hi Hove,
So are you saying that you shortened the wires with the latest version of Jessie and it worked for you?
Thanks,
Robert
Hove
Tue May 30, 2017 6:15 pm
Haven't tried the latest jessie, but for all between January and March, using the full length cables (with or without the electrolytic) always cause corruption / noise on I2C. Shortening them as short as you can always fixes the problem.
KrookdFinger
Thu Jun 01, 2017 7:08 pm
Hi Hove,
Just an FYI... This is causing the issue for me at least.
May be helpful if anyone upgrades...
http://www.robotshop.com/forum/post-p130228#p130228
KrookdFinger
Thu Jun 01, 2017 7:15 pm
Latest Kernel Patch for i2c discussed here
https://patchwork.kernel.org/patch/9351755/
Hove
Thu Jun 01, 2017 8:27 pm
KrookdFinger wrote:Latest Kernel Patch for i2c discussed here
I'll stick with my March RPi kernel then until I've got time to read the details of what's posted - thanks for sharing.
