MadPatch
PuTTY Connection Refused
Wed Mar 15, 2017 10:26 pm
Hi, I am very new to raspberry pi, I am running the newest Raspbian (NOOBS) and am trying to connect through PuTTY with SSH and at first it gave the error Connection Refused and then I fixed it by enabling SSH but now it gives the same error but I have SSH enabled can anyone help?
vamsi B3
Re: PuTTY Connection Refused
Thu Mar 16, 2017 2:26 am
hi i have the same problem, if you got the solution regarding that, will you help?
KLL
Thu Mar 16, 2017 2:38 am
MadPatch wrote:I fixed it by enabling SSH
you want to say that you already had a situation where the putty login worked?
you remember what you changed inbetween?
check RPI IP
if the router give that IP to a other device at boot the RPI could get a new IP.
and check if SSH enabled again.
MadPatch
Thu Mar 16, 2017 7:56 pm
No the IP stayed the same and I looked up every possible way to turn on SSH and it is definetly on. I can get VNC to work but is there a way to transfer files with VNC?
Patch
MadPatch
Thu Mar 16, 2017 8:02 pm
It just came to my mind when I tried another session, what does port 22 mean?
Could it be a promblem with that?
Also what other ways can I connect to my pi with being able to transfer files?
mad-hatter
Thu Mar 16, 2017 9:44 pm
'filezilla' works from the RPI and there is a Windows version, its just drag and drop.
Regards
nigelnigel
Thu Mar 16, 2017 11:43 pm
Hi ,
I'm only a few weeks into the Pi and had similar problems. I can't remember exactly what they were or the solutions but I eventually bumbled through them and it all works fine now. I found WinSCP the easiest program to install on my PC. It just seemed to have all the right default settings so it worked straight away. I am not sure if it is advanced at FileZilla but it does everything I need.
Might be worth a try?
Good luck
klricks
Fri Mar 17, 2017 1:55 am
MadPatch wrote:No the IP stayed the same and I looked up every possible way to turn on SSH and it is definetly on. I can get VNC to work but is there a way to transfer files with VNC?
Patch
Yes the RealVNC viewer has a built in file transfer tool. You can easily transfer files in either direction. Look in the toolbar top center of screen.
Also Copy & Paste works either direction.
