jveitch
Using program inputs over VNC
Fri Jan 20, 2017 6:31 am
Hello everyone,
Problem:
I have written a program in Python2 on my RPi and it runs happily.
The program takes a keystroke from the connected keyboard and turns on/off/speeds up a DC motor.
When I try to submit a keystroke from my MacBook Air via VNC the program does not accept the keystroke as an input to the program it just prints the keystroke.
I have VNC running and it seems to do everything it should be doing. I can connect to the RPi using SSH from my Mac. All connections seem fine, but I can not remotely "input" a keystroke.
What to do???
Thank you for any help.
It's hot here in Australia, hope it's nice where you are.
JV
jveitch
Re: Using program inputs over VNC
Fri Jan 20, 2017 6:41 am
Oh, I should have said I have a RPi-3-B, does that matter?
JV
mattmiller
Fri Jan 20, 2017 7:41 am
Don't know but posting your code inside code tags would help others help you :)
Cancelor
Fri Jan 20, 2017 7:58 am
as a possible work around, although I am sure it is fixable, try the on screen keyboard of the RPi
Can't find the thread you want? Try googling : YourSearchHere site:raspberrypi.org
