RDK
Connecting a Pi to a PC
Mon Jan 16, 2017 2:29 pm
I've tried to search on this topic but was not successful. My question is can I connect my Pi directly to a PC or laptop (Ethernet or USB) and then interact with it using PUTTY or some other program?
I know that if the Pi is on my network with an IP address I can get to it using PUTTY. But, what if I'm travelling (car, train or plane) and want to do something on the Pi, but don't have an available network?
Just curious.....RDK
Re: Connecting a Pi to a PC
Mon Jan 16, 2017 2:52 pm
Which model of Raspberry do you have?
This is a doctor free zone.
mattmiller
Mon Jan 16, 2017 3:04 pm
A working method is to set a static IP on the Pi to 169.254.64.64 and then you can just use that address if you plug it into a PC ethernet port as your PC will allocate itself an address in the 169.254 range
There is a chicken and egg situation over editing the Pi address (especially when going back to DHCP) but if you wireless DHCP at home and static ethernet away then no problem :)
Another common method is to turn your phone (if its a 'droid) into a hotspot with same name/password as your home setup) and then just use that on the road
RDK
Tue Jan 17, 2017 5:57 am
Dougie....It could be either a Raspberry Pi B+ or a Raspberry Pi v2, and the OS could be either Wheezy or Jessie. I have those combinations. As I said this is more of a curiosity than a real need....RDK
Matt. Interesting, I'll have to give these a try.....RDK
Wed Jan 18, 2017 12:47 am
B+ and 2B are easy.
Connect them with a cat5 cable.
Add ip=169.254.3.14 to the end of /boot/cmdline.txt
Reboot the RPi and use PuTTY to connect to 169.254.3.14
mattmiller
Wed Jan 18, 2017 7:02 am
I thought that feature was removed ages ago?????
Does it still work?
Wed Jan 18, 2017 7:56 pm
Does it still work?
Yes. It's part of the kernel NFS root file system support. The only thing to note is that if the eth0 interface isn't connected to anything you WILL get a two minute boot delay.
mattmiller
Wed Jan 18, 2017 8:31 pm
Well - thats good news :)
Does it just get applied to eth0?
Not wlan0 or PiZero using USB networking?
Wed Jan 18, 2017 8:57 pm
I've only ever done it with eth0.
http://fscked.org/writings/clusters/nfsroot.txt says you can use other devices.
mattmiller
Wed Jan 18, 2017 9:03 pm
I'll have to have a play with the parameters and see if we are lucky for PiZero USB peer-peer networking :)
mattmiller
Wed Jan 25, 2017 2:06 pm
@dougie
Tried
ip=192.168.0.224:::::wlan0
but no joy
Not really surprising I suppose as prob too early in the initialisation sequence for wlan0 to be enabled at that point
Wed Jan 25, 2017 3:24 pm
Looks like I'll need to do an experiment with my A+ (my Zero is busy doing a long term project).
procount
Wed Jan 25, 2017 3:45 pm
My usual technique to connect my RPi over ethernet to my PC is to simply run TFTPD32 http://tftpd32.jounin.net/tftpd32_download.html on my laptop as a DHCP server.
That way I don't have to modify my Pi network configuration - I just plug it in and the PC assigns it an IP address.
I use a separate USB-Ethernet dongle on my PC so that I can assign a static IP address to it and not interfere with my PC's own client dhcp connection to other networks.
mattmiller
Wed Jan 25, 2017 4:27 pm
Nice find :)
How do you config it to act as DHCP?
And how do you then know what IP it hands out?
Martin Frezman
Wed Jan 25, 2017 4:34 pm
Which OS do you run on your "laptop" ?
If this post appears in the wrong forums category, my apologies.
procount
Wed Jan 25, 2017 4:37 pm
Pretty simple - go into settings, select DHCP and enter the appropriate values for your DHCP pool, e,g, Pool start address, size of pool, lease time, router info etc. I just bind it to the usb ethernet dongle so that it doesn't answer on any other interface.
It shows you all the IP addresses that it hands out to what MAC addresses, the time they were allocated and when the renewal time is,
It can also act as a syslog server, and a tftp server (of course) for bootp etc.(if you want to use PXE on a Pi3, for example)
I have used it on WinXP and Win7.
RDK
Fri Jan 27, 2017 10:36 pm
@matmiller...
That works and I pretty slick.
I'm working on the option to connect it directly to the laptop with an Ethernet cable. May get to it this weekend. Will a normal Ethernet cable work or does it need to be a cross-over cable. This experiment will be a B+ with Jessie or a Pi V2 with Jessie.....RDK
mattmiller
Fri Jan 27, 2017 10:38 pm
Yep Pi do auto-xover
RDK
Fri Feb 10, 2017 12:33 am
Folks....
A working method is to set a static IP on the Pi to 169.254.64.64 and then you can just use that address if you plug it into a PC Ethernet port as your PC will allocate itself an address in the 169.254 range
Over the past few days I've experimented with just plugging eth0 on a Pi V2 Jessie into the Ethernet port on my Win 10 laptop. Using a monitor, of course, to monitor the boot up. The laptop consistently assigns itself 169.254.54.112 and the Pi 169.254.167.89. Using Putty I can connect to the Pi.
Thus, this seems to work well as did using the Hotspot on my cell phone.....RDK
ps....Don't have a Pi running Wheezy with me, but I will try that later....
mattmiller
Fri Feb 10, 2017 7:03 am
mm- interesting.
I've never bothered checking this as I'd assumed they were just random
I wonder if computers use some algorithim based on MAC addresses of the interfaces?
tweak42
Fri Feb 10, 2017 9:08 am
mm- interesting.
If there is it's probably in RFC 3927.
https://en.wikipedia.org/wiki/Link-local_address
RDK wrote:I've tried to search on this topic but was not successful. My question is can I connect my Pi directly to a PC or laptop (Ethernet or USB) and then interact with it using PUTTY or some other program?
You could create a static IP entry on the SD card and Windows interface or you could just let both devices auto assign 169.254.x.x address.
Then to find a headless Pi's address from a Windows computer, you will need zeroconf installed to resolve raspberrypi.local to that address.
Some popular applications include it or you can install Bonjour.
https://learn.adafruit.com/bonjour-zero ... x/overview
After booting up and letting both devices find each other, you should be able to ssh and ping raspberrypi.local
Additionally, if you happen to be connected to the internet via wifi, you can also bridge your wifi to ethernet connections to share the internet to the attached Pi.
http://www.windowscentral.com/how-set-a ... windows-10
RDK
Fri Feb 10, 2017 3:07 pm
Thanks. You guy are full of good and interesting ideas. I'll let you know how I make out with a Wheezy build when I get access to one....RDK
