cn130899
Lora
Sat Jun 11, 2016 10:49 am
Hi
I am an absolute biginner with the rasberry pi. I'me integrating it into a rocket to fire engines and do some monitering and i would like to be able to transmit this data to a laptop. I looked on the internet and i stumbled on a radio transmission system called LoRa and i think it would suit my purposes but i don't know what hardware i need and how it works.
Could you help me out?
Re: Lora
Sat Jun 11, 2016 4:29 pm
cn130899 wrote:Hi
http://www.daveakerman.com/?p=1719
https://store.uputronics.com/index.php? ... duct_id=68
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
drgeoff
Re: Lora
Sat Jun 11, 2016 9:06 pm
@cn130899
Could you please let us all know when and where you'll be launching. I and possibly many others will not wish to be in the vicinity.
DavidGMX
Re: Lora
Wed Jul 06, 2016 10:03 am
Hi,guys,
The Dragino Lora/GPS_HAT is a expension module for LoRaWan for ues with the Raspberry Pi.This product is intended for those interested in developing LoRaWAN solutions.
You can get more info about the Lora/GPS_HAT from http://wiki.dragino.com/index.php?title=Lora/GPS_HAT
Hope it help to the people who need it.
Re: Lora
Wed Jul 06, 2016 10:14 am
adieu
FlexibleSigmoid
Re: Lora
Wed Jul 06, 2016 3:32 pm
But does it GPS?
zoelqivlie
Re: Lora
Mon Dec 12, 2016 3:24 am
I used LoRa GPS/HAT but gps didn't function , followed the dragino tutorial from
http://wiki.dragino.com/index.php?title ... _3_Model_B
didn't work , blank data when call "sudo cat /dev/ttyS0" , all config and prameters are same with tutorial , used 5v 3A adaptor and outdoor , cgps no fix....
used other LoRa GPS and Raspberry Pi 3 ...didn't working ;-(
but I used Itead GPS v2 shield ...worked
device :
- Raspberry Pi 3 with Jessie Pixel
- LoRa /GPS HAT
- 5v 3A Adaptor
any solution? thank you
tkraspilabs Indonesia | Pi 512M Rev 2 | Pi B+ | Pi 2 B | Pi Zero | Pi 3B
Gavinmc42
Re: Lora
Mon Dec 12, 2016 4:09 am
Adafruit Feather M0 LoRa in Rocket, Pi in basestation?
You could make it simpler by using two LoRa Feathers and serial output via USB to Pi.
Took me an hour to get comms example code working.
Takes longer to find/install tools and libraries than cut paste code/compile/program :o
Got Arduino IDE working on Pi 3.
You need two PC's/Pi 3 to test/write/debug, one for each feather.
Next use Zero with LoRa module to get video?
I'm dancing on Rainbows.
