dasmanul
Re: so frustrated
Wed Jun 01, 2016 9:17 pm
Okay, thanks. You seem to have done a lot of things as root, using 'sudo' which I wouldn't recommend. However, to get you up and running as fast as possible, we'll leave it at that for now. Please enter
sudo crontab -e
and delete the last 2 lines (starting with '*/1'). Then enter a new line like this:
* * * * * /usr/bin/temperv14 >> /home/pi/temperv14/temper1.txt
This should put the output of the temperv14 command into the specified file every minute. To verify, wait a couple of minutes and then enter
cat /home/pi/temperv14/temper1.txt
Please note that the leading '/' before 'home' is important - you seem to have omitted that in a couple of places.
Let us know whether that works.
W. H. Heydt
Re: so frustrated
Wed Jun 01, 2016 11:19 pm
dasmanul wrote:Okay, thanks. You seem to have done a lot of things as root, using 'sudo' which I wouldn't recommend. However, to get you up and running as fast as possible, we'll leave it at that for now. Please enter
sudo crontab -e
A way to watch the output in the file is to use "tail -f <filename>". The "-f" makes tail "follow" the file contents rather than just giving you the last few lines and then stopping (or even the whole file as "cat" does).
loopylee
Re: so frustrated
Thu Jun 02, 2016 6:23 am
sudo crontab -e
That is perfect, it is now doing exactly what i wanted it to do.
Thanks you very much, and thanks to you all for your patience.
dasmanul
Re: so frustrated
Thu Jun 02, 2016 7:09 am
Thanks for the feedback, glad I could help. Have fun with your Pi (and your greenhouse)! ;)
Cancelor
Re: so frustrated
Thu Jun 02, 2016 9:07 am
I'm very glad to see this is solved and want to add praise for dasmanul in achieving it. :D If we had a 'citizen of the month' award then he would be my nomination.
There have been a few very frustrated posts recently. I'm wondering if there is a collective way we can all learn how to handle them?
Can't find the thread you want? Try googling : YourSearchHere site:raspberrypi.org
dasmanul
Re: so frustrated
Thu Jun 02, 2016 10:02 am
Ah, come on, now you've made me blush. :D I have a rather low tolerance for frustration myself, so I just couldn't let it sit...
W. H. Heydt
Re: so frustrated
Thu Jun 02, 2016 4:29 pm
Cancelor wrote:I'm very glad to see this is solved and want to add praise for dasmanul in achieving it. :D If we had a 'citizen of the month' award then he would be my nomination.
You handle them with patience, understanding and sympathy. You remind yourself that we were *all* beginners at one point, so be welcoming to those new to any subject. Someday they may be the expert that *you* go to for answers when you are frustrated.
(I read threads like this to fill gaps in my own knowledge. Sometimes I learn something and sometimes I don't. Sometimes I may even find some point I can contribute to.)
