pabloclsn
Send A Electric Signal from the raspberry Pi Zero
Thu Apr 28, 2016 7:35 am
Hi guys, i would like to know if it's possible to Start my computer with my Rasp Zero, not with WAKEONLAN or things like that, just an electric signal as if i was pushing the power button. From a internet WebSite for example. Thanks
LetHopeItsSnowing
Re: Send A Electric Signal from the raspberry Pi Zero
Thu Apr 28, 2016 10:15 am
You are going to need some sort of relay which can switch your computer on based on a signal from your Pi.
It sounds like a very doable project.
"am I getting slower, or is stuff more complicated; either way I now have to write it down - stuffaboutcode.com"
hippy
Thu Apr 28, 2016 11:42 am
It should be possible. The PC motherboard will likely have a variety of 'wake on' inputs which can be connected to using a relay, opto, transistor or even directly.
Paralleling a relay contact with the power button is the easiest and safest route. Wake On LAN and Wake On Modem ( Wake On Ring ) header pins are often the most convenient to directly interface to if available though a direct power button interface is also possible
