How to get and install an HP M276nw driver?
Posted: Sun Mar 20, 2016 11:43 am
by typxxi
I have this MFP laser from HP and can't find a way to install this device.
I found some informations about an hp repository where the HP M276nw should be part of but I did not find the right ppd driver file and a step by step solution.
Thx for any further help and descriptions about this CUPs adventure.
Re: How to get and install an HP M276nw driver?
Posted: Sun Mar 20, 2016 12:06 pm
by fruitoftheloom
typxxi wrote:I have this MFP laser from HP and can't find a way to install this device.
If it is actually a HP LaserJet Pro 200 Color MFP m276nw
http://hplipopensource.com/hplip-web/mo ... 276nw.html
Supported by HPLIP 3.12.9, therefore Raspbian Jessie and:
sudo apt-get update
sudo apt-get install hplip cups
You need to be a member of lpadmin group
sudo usermod -a -G lpadmin pi
http://www.penguintutor.com/linux/printing-cups
Posted: Sun Mar 20, 2016 7:00 pm
by typxxi
Hey,
unfortunately even after a reboot I am not able to install a printer.
If I open the website (http://192.168.xxx.xxx:631/) I see V 1.7.5 and if I try to add a printer I get a connection refused error from http://192.168.xxx.xxx:631/admin.
Any ideas?
Thx
P.S.: It's a connection problem: 127.0.0.1:631 works
Posted: Sun Mar 20, 2016 7:11 pm
by DougieLawson
Change the config to allow connections from anywhere in the 192.168.xx.xx/24 subnet.
Try httpS://192.168.3.14:631 (changed to your hidden address) and login with your pi userid (as long as pi is in the lpadmin group)
Posted: Sun Mar 20, 2016 8:20 pm
by typxxi
OK, here a few comments:
On the raspi I am able to open the cups admin page via 127.0.0.1:631 and to add a printer.
If I am trying to select the modell the ephiphany Browser is running under heavy load.
The first problem is that there are 8 or 10 drivers with the exact same description - no difference.
The second problem: I do not get an add button to add the selected printer modell.
Even after a minute there is a still growing list of HP Printers where I can select the right one but there is still no button for adding this printer.
If I start TOP in the terminal session I see the browser running at 103% ... but nothing happens for minutes inside the browser window where the progress bar stays still.
stop, after 5 or 6 minutes while typing here the site was completly loaded and now there is the add button.
Posted: Sun Mar 20, 2016 8:53 pm
by DougieLawson
Change this stuff in /etc/cups/cupsd.conf
Listen 0.0.0.0:631 # change me
<Location />
  Order allow,deny
  Allow @LOCAL # change me
</Location>
<Location /admin>
  Order allow,deny
</Location>
<Location /admin/conf>
  AuthType Default
  Require user @SYSTEM # leave me alone
  Order allow,deny
</Location>
restart cupsd and you'll be able to access it from ANY machine in your local subnet. It's a bunch easier doing it from Firefox or Chromium on Windows. If you can't do that install Chromium 48 on your RPi (because that's less likely to crash than Epiphany).
Posted: Sun Mar 27, 2016 10:43 am
by typxxi
Thanks Dougie, but unfortunatelly I have more questions than answers :roll:
I don't know if something went wrong, but when I tried this sudo nano /etc/cups/cupsd.conf I found only one "listen".
That syntay looked very different to your "Listen 0.0.0.0:631 # change me" and therefore I am asking
# Allow remote access
Port 631
Listen /var/run/cups/cups.sock
Shall I change "Listen /var/run/cups/cups.sock" into "Listen 0.0.0.0:631" or the IP of my Win 10 Laptop?
I am not sure if 0.0.0.0 is something like a mask.
What else do I have to do at the "change me" lines?
<Location />
Order allow,deny
Allow @LOCAL # change me (into what? my laptop IP adress or just delete @LOCAL)
</Location>
<Location /admin>
Order allow,deny
</Location>
AuthType Default
Require user @SYSTEM # leave me alone (what do I have to do here?)
Order allow,deny
Sorry, but I am very unfamiliar with that stuff and I do not want to make a mistake and restore the SD again and again.
Posted: Sun Mar 27, 2016 5:05 pm
by DougieLawson
Posted: Sun Mar 27, 2016 7:28 pm
by typxxi
Hey,
that works fine. The web page with the selection of HP Pinter is now - on my W 10 Laptop - instantly (fast) available and no page forward waitings I had on my raspi epiphany browser.
Great job, well done.
If any other might follow: to restart cups try this sudo /etc/init.d/cups restart
Meanwhile I got chromium running on my newest raspi 3 B where it amazing fast(er) than on the 2 B.
Thx a lot for all of your support. :D
Posted: Sun Mar 27, 2016 8:02 pm
by typxxi
I checked this with the initial conf file I got from the installer and at first sight I was confused and it looked like that all CHANGE ME lines were already adapted, but I was wrong.
DougieLawson wrote:Change this stuff in /etc/cups/cupsd.conf
<Location />
  Order allow,deny
</Location>
<Location /admin>
  Order allow,deny
</Location>
  AuthType Default
  Order allow,deny
</Location>
I only had to change better add these 2 lines
Listen 0.0.0.0:631 # ADD ME
<Location /admin>
  Order allow,deny
  Allow @LOCAL # ADD ME
</Location>
Restart cupsd: sudo /etc/init.d/cups restart
But thanks again for your quick and efficient support.
