SD Card Corruption
Posted: Thu Dec 31, 2015 10:52 am
by RDK
Yes, there are lots of posts out there on this issue. So far I have not had the problem with my 3 Pi's, but I'm trying to think ahead.
Aside from UPS power and surge protection, the other popular idea is the set up some of the filesystem as temporary RAM disks. This is proposed several places https://raymii.org/s/blog/Broken_Corrup ... _Card.html and http://www.ideaheap.com/2013/07/stoppin ... pberry-pi/. However in the latter reference there is a "disclaimer" following some suggested code:
The following two lines should be added to /etc/fstab:
none        /var/run        tmpfs   size=1M,noatime         00
none        /var/log        tmpfs   size=1M,noatime         00
UPDATE (unverified): I have been told that /var/run is now a symlink to a tmpfs filesystem, anyways, so you may not need to add /var/run anymore, and adding it may cause issues.
Thus my question is should I try this method to minimize writes to the SD card or is it no longer an issue?
And, what about using the noatime option?
Thanks for your time...RDK
Re: SD Card Corruption
Posted: Thu Dec 31, 2015 11:05 am
by jahboater
For Pi2's with their 1GB of memory, I always add the two tmpfs filesystems.
Normally when a file is read its last access time is recorded. This is rarely useful and means that for every "read" there is an additional "write". Adding "noatime" is a common optimisation to avoid this.
proc /proc proc defaults 0 0
/dev/mmcblk0p1 /boot vfat defaults 0 2
/dev/mmcblk0p2 / ext4 defaults,noatime 0 1
# a swapfile is not a swap partition, no line here
# use dphys-swapfile swap[on|off] for that
tmpfs /tmp tmpfs defaults,noatime 0 0
tmpfs /var/log tmpfs defaults,noatime,size=64m 0 0
Note the "size=" field is just a maximum - the file system takes only as much memory as the files actually use (plus about 100k fixed overhead). It is virtual memory, shared with everything else. If the size= field is omitted then the maximum is half the computers memory size (in this case 512MB).
Obviously memory is much faster than SD card access, so apart from reducing the disk writes, it may speed up some things like compilations.
Posted: Thu Dec 31, 2015 1:34 pm
by RDK
OK, I understand the philosophy of the RAM drives, but my question goes back to the disclaimer in that reference. Should we be doing that if those filesystems are
....RDK
Posted: Thu Dec 31, 2015 4:50 pm
by jahboater
If the directory is already a symlink (symbolic link) to an existing tmpfs file system then just leave it - its been done for you.
On my Pi2
file /var/run
reports that it is a symbolic link to /run as does /var/lock which is a symlink to /run/lock.
As memory gets cheaper its more and more common for distro's to come with some tmpfs directories - usually /tmp. These wont be in /etc/fstab.
Posted: Sat Jan 02, 2016 3:33 pm
by RDK
Thanks. OK, I'll give it a shot ont he unit I working on right now....Rob
