Hiro
Apache configuration
Sun Jul 29, 2012 10:01 am
I am trying to host a web site on my Pi so i installed apache.
sudo apt-get install apache2
Started the service
sudo /etc/init.d/apache2 start
Did a google for apache configuration to find out where to put the web pages and found i needed to edit the "documentroot" line in the httpd.conf file. Problem is i don't have that file anywhere, i assume httpd is a daemon? if so it is not installed and running but apt-get tells me it cannot be installed but is part of apache2, is this correct?
I think apache may be working ok as if i type http://localhost into midori i get the "It works" page which i seem to think is an apache thing?
I'm a little confused so any help would be appreciated.
Cheers, Hiro.
PIstolero
Location: paradise city, where the grass is green and the girls are pretty
Re: Apache configuration
Sun Jul 29, 2012 10:08 am
I never installed apache on a Pi but on debian (raspbian is based on debian) the config file is apache2.conf (not httpd.conf); it should be in /etc/apache2.
Jim JKla
Sun Jul 29, 2012 10:10 am
If you got the it works page it sounds good.
sudo su
that makes you super user
cd /var/www
go to the dark place where your web pages for apache are
ls
this is the eqivilent of the old dos dir command you can use nano to edit the html and play in general.
remember you may need to chmod 755 "the file name" to make new html's public readable if it's a new file but thats basic web page stuff.
Noob is not derogatory the noob is just the lower end of the noob--geek spectrum being a noob is just your first step towards being an uber-geek ;)
If you find a solution please post it in the wiki the forum dies too quick
Hiro
Sun Jul 29, 2012 10:20 am
@ Pistolero The apache2.conf file is present but there doesn't seem to be anywhere that tells my where the html files should be stored.
@Jim JKla That does seem to be where they are stored but i would really like to store them somewhere else. I suppose i could just link the directory but i feel there must be a line somewhere in some config file
to change that?
Thanks for the help, Hiro.
PIstolero
Sun Jul 29, 2012 10:26 am
Sorry, it is apache2 not 1.x.
In the folder /etc/apache2/sites-enabled/ there should be a file 000-default
Jim JKla
Sun Jul 29, 2012 10:29 am
You can store them somewhere else then you need to set up a symbolic link then you can have them in your home directory whatever.
As fo setting up sybolic link info thats kind of generic linux and there's loads of info on the net. ;)
Hiro
Sun Jul 29, 2012 10:36 am
That's the file i was looking for Pistolero, just need to edit:
 DocumentRoot /var/www
Thanks for that, Hiro.
Return to “Beginners”
