bdr9
How to install ffmpeg on Raspberry Pi 2
Sat Nov 07, 2015 6:53 pm
I need ffmpeg in order to set up a Subsonic audio-streaming server on my Raspberry Pi 2.
When I run sudo apt-get install ffmpeg:
pi@raspberrypi2 ~ $ sudo apt-get install ffmpeg
Reading package lists... Done
Building dependency tree
Package ffmpeg is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'ffmpeg' has no installation candidate
I also heard that ffmpeg is included in libav-tools. When I try to install that, it installs, but ffmpeg is still not in /usr/bin. Does anyone know how to install ffmpeg on the Raspberry Pi 2?
Re: How to install ffmpeg on Raspberry Pi 2
Sat Nov 07, 2015 9:18 pm
https://wiki.debian.org/ffmpeg
fyi Raspbian Wheezy is based of Debian 7 whilst Jessie is based of Debian 8
Retired disgracefully.....
bdr9
Sat Nov 07, 2015 9:21 pm
fruitoftheloom wrote:https://wiki.debian.org/ffmpeg
Thanks for the link. On that page, they suggest using apt-get install libav-tools and apt-get install ffmpeg, but I said in my original post that I already tried both of those. libav-tools installed successfully but did not give me ffmpeg. When I tried to install ffmpeg directly, I got the error shown in my post above.
Any help would be appreciated.
Sat Nov 07, 2015 9:23 pm
Thanks for the link. On that page, they suggest using apt-get install libav-tools and apt-get install ffmpeg, but I said in my original post that I already tried both of those. :D libav-tools installed successfully but did not give me ffmpeg. When I tried to install ffmpeg directly, I got the error shown in my post above.
Libav is a fork of FFmpeg that we can find in the Debian repositories. If you want to use ffmpeg, you will juste need to change the word "avconv" to "ffmpeg" in the different commands lines, the rest stay the same.
It would help if you had stated you had installed Raspbian Jessie because the RPi 2B is only the hardware :D
bdr9
Sat Nov 07, 2015 9:28 pm
Actually, I didn't even know that there are two different versions of Raspbian! I just installed the one that the Noobs installer gave me. :lol: That makes sense now. I do have avconv installed. So you are saying that I can use avconv interchangably with ffmpeg? Can I rename the avconv binary to ffmpeg if my server software expects ffmpeg?
Sat Nov 07, 2015 9:34 pm
bdr9 wrote:Actually, I didn't even know that there are two different versions of Raspbian! I just installed the one that the Noobs installer gave me. :lol: That makes sense now. I do have avconv installed. So you are saying that I can use avconv interchangably with ffmpeg? Can I rename the avconv binary to ffmpeg if my server software expects ffmpeg?
AFAIAA you just change the name in the actual written commands....
fyi https://www.raspberrypi.org/downloads/raspbian
dtb1987
Wed Aug 03, 2016 5:24 pm
How do i change the command to ffmpeg?
Bottersnike
Wed Aug 03, 2016 6:08 pm
dtb1987 wrote:How do i change the command to ffmpeg?
You can create an alias. If you type
alias ffmpeg=avconv
into a terminal them ffmpeg wil execute avconv. To automate that, edit your
~/.bashrc
file and just add
alias ffmpeg=avconv
to the end.
Micro:Pi is an (almost) fully fledged IDE for programming a BBC Micro:Bit using C++. Go check it out at https://bottersnike.github.io/Micro-Pi
dtb1987
Thu Aug 04, 2016 11:59 am
thierryr
Sat May 20, 2017 8:24 pm
Post digging. Is there any news about ffmpeg.
Thank's
Sun May 21, 2017 10:12 am
thierryr wrote:Post digging. Is there any news about ffmpeg.
Thank's
It would appear that ffmpeg will be returning in Debian Stretch.
Though as stated above libav = ffmpeg
https://packages.debian.org/stretch/ffmpeg
sanfx
Sun Jun 18, 2017 3:26 pm
trying to install ffpeng gives package not found error
:~ $ sudo apt-get install ffmpeg
how should I fix this ?
johndavies
Sun Jun 18, 2017 4:30 pm
Look on the square penguin site (https://squarepenguin.co.uk). Choose "Download".Click on Linux/BSD.
Click on the first site mentioned.You could choose to download Raspbian get_iplayer if you live in the
UK and have a valid TV licence. Scroll to the bottom of the page. Enter the four lines one at a time
changing 64 bit to armhf-32 bit before you press "Enter". If ffmpeg is not loaded, as it was not for me
on the Raspberry Pi 2, repeat the above but begin the lines where it does not come first with "sudo".
SurferTim
Sun Jun 18, 2017 10:41 pm
I downloaded and compiled ffmpeg from the source. Download ffmpeg-3.3.2.tar.bz2
https://www.ffmpeg.org/download.html
Unpack it.
tar -xvf ffmpeg-3.3.2.tar.bz2
then change to that directory and:
./configure
make
sudo make install
photoJames
Wed Jul 19, 2017 8:01 pm
Thanks SurferTim, I'm on the next to last step on a Pi Zero W over ssh. Is there a way to trim down the number of codecs installed to just the ones I'm going to use? The reason I ask is that this is taking a very long time to complete as the Zero is not a speed demon in any sense of those words. lol. Thanks again!
James
SurferTim wrote:I downloaded and compiled ffmpeg from the source. Download ffmpeg-3.3.2.tar.bz2
Unpack it.
./configure
make
sudo make install
SurferTim
Wed Jul 19, 2017 8:31 pm
It takes quite a while to compile on an RPi3. Is it the compile time you are worried about?
Imperf3kt
Mon Jul 24, 2017 1:53 am
It took me 40 or 50 minutes to compile on my Pi3b. I do not recommend doing it on a zero
By the way, the debian multimedia repositories have a great guide on the process.
55:55:44:44:4C
52:4C:52:42:41
phiphonemo
Wed Sep 27, 2017 9:41 am
You can fix it with this
https://sourceforge.net/projects/ffmpeg ... bserver.p/
Martin Frezman
Wed Sep 27, 2017 11:26 am
What is the current state of the ffmpeg/avconv kerfluffle?
I know that originally there was ffmpeg, then the keeper/author/whatever of that program had a psychic breakdown of some sort and they had to spin off avconv. For a while you had to use avconv for some things, ffmpeg for others. It was confusing. The goal had been to re-merge the two programs at some point. Has that happened yet?
If this post appears in the wrong forums category, my apologies.
Wed Sep 27, 2017 5:29 pm
Resurrecting old post is prone to causing confusion, considering this post has been through Wheezy and Jessie cycles.
Fortunately with the current supported Raspbian (based of Debian 9.x) Stretch - ffmpeg package is now default in the repositories:
https://packages.debian.org/en/stretch/ffmpeg
libav-tools has now become a transitional package in Stretch
https://packages.debian.org/en/stretch/libav-tools
Return to “Beginners”
