planetscape
Re: USB HDD
Sat Nov 30, 2013 2:39 am
Thanks for the prompt replies.
Actually, I think I have resolved my problem. Before I could implement your
advice, I barely bumped the USB hub and the power failed. That led to a
corrupt SD card, and time spent rebuilding to the point where I could try
setting up to run my Pi from an ext HD. Once I replaced what was obviously a
flaky USB Hub, the problems I described in my first post went away.
So, again, thank you all so much for your attempts to help me. I do think,
however, that it was all down to a faulty USB Hub. For anyone who has similar
issues, if you can, swap out your hub, just to be sure that's not the problem.
Thanks again!
(Cross-posted to:
The Raspberry Pi Hobbyist: Running From an External Hard Drive
http://raspberrypihobbyist.blogspot.co. ... drive.html)
tedhale
Re: USB HDD
Sat Nov 30, 2013 2:53 pm
The poster that I was responding to now reports that his problem seems to have been caused by a flaky USB hub.
- Ted B. Hale
http://raspberrypihobbyist.blogspot.com
mech259
Re: USB HDD
Sun Apr 12, 2015 2:24 am
When I did a sudo e2fck /dev/sda1, got thousands of errors, yes all of them, did all proper commands. Went to reboot and got hundreds of errors. boots to command line with no wifi. All corrupted.
squakie
Re: USB HDD
Tue Apr 19, 2016 5:26 am
I know this is an old thread, but still useful. It would be best to actually specify the uuid via UUID="xxxxxxxxxxx" in fstab. If you were to plug in another USB device such as a USB thumb drive, when you boot again you don't know which it will try to mount first, so /dev/sda1 may have suddenly become the USB thumb drive and guess what - no boot! By specifying the UUID instead you can be sure it is always use the correct drive.
This same change applies to cmdline.txt - changes /dev/sdax to UUID="xxxxxxxxxxxx" and it will always try to boot using the hard disk.
Return to “Beginners”
