Krassegrand
I am thinking about buying a "Raspberry kit".
Sat Apr 25, 2015 3:33 pm
My first project will be to have the Raspberry as a media player with USB to a hard drive and HDMI to the TV.
What do I need for this first instalment?
I have a blue tooth keyboard and mouse, I have the cables.
I guess I need,
the card (witch model?)
SD-card (how big?)
Card holder?
I am using Ubuntu in my PCs is that making it harder or easier?
Jörgen
kusti8
Re: I am thinking about buying a "Raspberry kit".
Sat Apr 25, 2015 4:04 pm
If you already have a keyboard and mouse, I wouldn't buy a kit.
1) get the raspberry pi 2
2) 8 GB size would be ideal.
3) you're going to need a power supply. 5V 2A is the best.
Ubuntu will make the process much easier than Windows.
Have fun! ;)
pluggy
Sat Apr 25, 2015 4:32 pm
kusti8 wrote: Ubuntu will make the process much easier than Windows.
+1 By an order of magnitude in my opinion.
mahjongg
Sat Apr 25, 2015 5:17 pm
Type of SD-card doesn't really matter, but look out for fakes, buy from a reliable supplier.
don't start with extreme card sizes on your first try, for example special measures are needed when using 64GB cards.
most micro-SD-cards come with a card holder, so you can program the card in a programmer meant for regular size cards.
the card connector on a PI is very small, so fragile so handle with care. it's a push to insert - push to release card connector, so don't try to pull out the card, or you may damage the card connectors locking mechanism.
Krassegrand
Sat Apr 25, 2015 5:41 pm
Thank You all for the quick answers
kusti8 wrote:If you already have a keyboard and mouse, I wouldn't buy a kit.
Good
Good again
I will have a look in the garage to see what I have lying around
Sounds good!
Have fun! ;)
Thank You!
I like Your signature!
There are 10 types of people in the world. Those that understand binary and those that don't.
Krassegrand
Sun Apr 26, 2015 5:10 am
I have ordered a "Raspberry Pi 2 Model B 1GB RAM" and a "SanDisk microSDHC 8GB Card + SD Adapter - Class 4" from CDON.COM.
Thank You guys.
I will get back to You about installing.
Jörgen
Krassegrand
Tue Apr 28, 2015 11:04 am
My unit is on the way!
If I want to use it as a mediaplayer, do I use this installation guide?
https://github.com/raspberrypi/noobs/bl ... x-software
Jörgen
PS
I use Ubuntu as a OS
kusti8
Tue Apr 28, 2015 11:15 am
Krassegrand
Tue Apr 28, 2015 4:47 pm
My unit has arrived!
kusti8 wrote: 3) you're going to need a power supply. 5V 2A is the best.
I have one 6V and 300mA
Is that way off?
Jörgen
PS
I am downloading raspex-ubuntu-15.04-armhf-923mb-150318.zip at the moment!
JimmyN
Tue Apr 28, 2015 4:53 pm
6 volts is too much and 300mA is not enough. It has to be a 5V supply.
Krassegrand
Tue Apr 28, 2015 4:58 pm
Ok!
It seem like the download is very slow so I will have time to get a better power supply! ;)
Jörgen
Krassegrand
Tue Apr 28, 2015 6:15 pm
I have the raspex-ubuntu-15.04-armhf-3050mb-150318.img on my laptop but I can't find the memory card on the laptop?
Jörgen
kusti8
Tue Apr 28, 2015 7:30 pm
It should just pop up. Try formatting it again with GParted if that sees it.
JimmyN
Tue Apr 28, 2015 8:12 pm
It should show up as D: or E: drive.
kusti8
Tue Apr 28, 2015 9:04 pm
JimmyN wrote:It should show up as D: or E: drive.
He's using Ubuntu, so it should show up under /media/ I'm pretty sure.
Krassegrand
Wed Apr 29, 2015 5:06 pm
/media
seems to be eampty ?????
I have started a thread on the Ubuntu forum about this!
Jörgen
gigapouch
Wed Apr 29, 2015 11:45 pm
This kit is a pretty good value: http://www.amazon.com/Guide--Clear-Case ... rry+pi+kit
It's only $70 and comes with a lot of goodies.
Krassegrand
Thu Apr 30, 2015 6:53 am
About the power supply, can I run it from a USB charger?
Jörgen
BMS Doug
Thu Apr 30, 2015 8:52 am
Krassegrand wrote:About the power supply, can I run it from a USB charger?
Jörgen
Many people do, but the quality of the output is important.
a standard USB phone "charger" normally outputs 5v but the amps rating will vary quite widely, the cheaper versions won't manage to reliably output the correct voltage at higher current flows. a decent tablet USB "charger" or a high end smartphone "charger" should be fine.
I keep saying "charger" as a charger doesn't have to meet the same specification for power supply as a USB power supply has to meet.
Doug.
kusti8
Thu Apr 30, 2015 11:18 am
You can always try out a charger if you are unsure. If there is a rainbow box in the top corner or the red power light is off, then its no good.
Krassegrand
Thu Apr 30, 2015 3:25 pm
Thank You guys!
So if I get over the problem with finding the memory card (on the laptop) I can try it out with a USB-charger until I buy a proper power supply.
Jörgen
kusti8
Thu Apr 30, 2015 7:48 pm
Yes if it works you don't even need a proper power supply.
Krassegrand
Thu Apr 30, 2015 7:58 pm
It is running now!
I just don't know how to watch video-files.
Jörgen
piBob
Thu Apr 30, 2015 8:38 pm
I would not buy a pi2b. The web pages do not explain things correctly. This forum is the pits. They will not answer your questions. If they do, no clue how it's done.
Krassegrand
Sat May 02, 2015 8:42 pm
I have had some problems with installing!
First I installed RasEX on a 8GB card but as it don't seem to be the best for watching movies I tried to install Noobs and it went as well as it can but only on my 4GB card and that seems a little small for Noobs.
I tried to do the same way on my 8GB card but it just wont start up.
Can it be something with the rights?
I am using Ubuntu on my PCs.
Jörgen
